I’ve just updated HA Core and OS, and now my Denon AVR integration is no longer working. Any idea if there’s anything I can do?
Logger: homeassistant.config_entries
Source: components/denonavr/receiver.py:66
First occurred: 09:25:39 (1 occurrences)
Last logged: 09:25:39
Error setting up entry Denon AVR-X2400H for denonavr
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 236, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/denonavr/__init__.py", line 71, in async_setup_entry
if not await connect_denonavr.async_connect_receiver():
File "/usr/src/homeassistant/homeassistant/components/denonavr/receiver.py", line 33, in async_connect_receiver
if not await self._hass.async_add_executor_job(self.init_receiver_class):
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/denonavr/receiver.py", line 66, in init_receiver_class
self._receiver = denonavr.DenonAVR(
File "/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py", line 344, in __init__
self.update()
File "/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py", line 527, in update
return bool(self._update_avr_2016())
File "/usr/local/lib/python3.8/site-packages/denonavr/denonavr.py", line 644, in _update_avr_2016
executor.submit(self._audyssey.update())
File "/usr/local/lib/python3.8/site-packages/denonavr/audyssey.py", line 109, in update
self.dynamiceq = bool(int(param.text))
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'
Same here, with a Marantz NR-1605 (which uses the Denon integration). My stack trace starts a little differently, but is the same from line 33, in async_connect_receiver down.
Lol same. I recently got a new amp for my subwoofer and a switch in HA that I sync with my receiver power status so it goes on/off automatically. So I hope they will publish it soon.
Yes it is working now
Offtopic: anybody willing to share how they configured their Denon AVR in lovelace (I’m assuming using the custom mini player).
The fact that the Denon AVR needs to be controlled by the Denon integration or the HEOS integration depending on what you’re trying to achieve makes it a bit challenging
Since Upgrade to core 6.4 my Denon x4400h cant be found by HA Integration anymore, IP is not reachable. Before it worked perfectly. Ive restarted the AVR, HEOS works fine… anyone else?
