I have a Marantz NR1504 AVR.
I tried the ‘denon’ and the ‘denon_avr’ components, but in both cases I can’t start Home Assistant. In debug log last message I see the home assistant loader (Loaded media_player.denon).
Can anyone help me?
Thank you!
Please use the code tags (the </> button in the editor toolbar) to post config snippets, otherwise indentation gets messed up.
Make sure that you have two spaces before “host” and “name”, i.e.:
UPDATE:
OK, one step closer. After AVR restart, I can start Home Assistant, but the AVR controls are missing from the dashboard, and I can’t see the entity in dev tools.
There are also no error messages.
Your config looks ok, that’s good.
If the component is unable to configure the device correctly, there should be some messages in the normal log file (i.e. the “( i )” button in the frontend).
I don’t know about your model, but mine has an option to disable networking in standby mode.
At least in my case, the denon and denon_avr controls behave a little strange, when they can’t reach the device at all.
So maybe it’s best to leave networking in standby enabled.
Hallo! Wasn’t sure who I should talk to about this - I’ve tested the Denon component with an RCD-N8 (it’s listed on the component’s documentation page as ‘untested’) and I’ve found it doesn’t work. @piotr-zuralski ?
I’m not saying ‘make it work!’ I’m simply saying how do I edit the page to reflect the face it’s now tested?
