Good morning,
I’ve been trying to integrate my HEOS 1 - Heos 3 or Heos home theater into HomeAssistant for days and just can’t get any further.
I have set the logging (configuration.yaml) to see where the error is. Unfortunately I can’t get a LOG. Unfortunately, I also don’t know how to create a service with the login data for the Denon Heos account under services. I am still new and unfortunately I can’t get any further. Therefore my request for help.
"Logger: homeassistant.helpers.script.websocket_api_script
Source: helpers/script.py:1934
First occurrence: May 11, 2024 at 11:05:36 (1 occurrences)
Last logged: May 11, 2024 at 11:05:36
websocket_api script: Error executing script. Service not found for call_service at pos 1: Service heos.sign_in not found"
I would be happy if someone can help me.
Good morning, the Denon HEOS devices are recognized. However, I cannot configure them.
There is no entry in the System/Protocols area.
I have entered this in the config file.
configuration.yaml
logger:
default: info
logs:
homeassistant.components.heos: debug
pyheos: debug
Denon AVR Network Receivers - Home Assistant ? No, I haven’t installed that. I don’t have any AVR receivers.
Do I really need this?
Ohhh, ok… Forget about the AVR part then, my mistake, just an wrong assumption
Well, the heos.sign_in service should be automatically added, when the device is recognized and added. It’s part of the setup. There should be no need to setup that service manually…
No, by “New devices discovered”
Connect to Heos
Please enter the host name or IP address of a Heos device (preferably one that is connected to the network by cable).
Host
Kitchen (192.168.168.24)
Home theater (192.168.168.32)
Office (192.168.168.34)
The host name or IP address of your HEOS device.
I don’t know, how the HEOS satellite device’s like your’s behave. I only have an AVR. Well, this reminds me of same looking problem, I had in the past.
I needed to solve it with two steps:
Firmware update
Buried somewhere in the settings of the Denon device I needed to enable LAN, when sleep. Initially that is disabled, so the device disconnects from LAN, when not used.
But as said, I don’t know, if speakers and soundbars are behaving the same way.
