HA detects my Denon Receiver as a integration…all fine.
However,if I want to use the same receiver as a DLNA playback device and I add this, it now shows twice (with a _2 at the end then). As it is the very same machine, should this not be combined?
This is correct behavior. You have two different integrations, that connect via two different ways with your Denon.
