Dependencies Broke after Update
Hey All:
Hoping you guys can identify which dependencies I’m missing. I upgraded my Ubuntu Server 17.10 install to 0.58 from 0.57.4 this morning through the pip3 install --upgrade homeassistant command. Now I can’t access Homeassistant at all.
Log attached:
2017-11-19 08:28:01 ERROR (SyncWorker_0) [homeassistant.util.yaml] YAML file /home/server/.homeassistant/configuration.yaml contains duplicate key "sensor". Check lines 58 and 87.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.frontend. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/loader.py", line 142, in get_component
    module = importlib.import_module(path)
  File "/usr/lib/python3.6/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 994, in _gcd_import
  File "<frozen importlib._bootstrap>", line 971, in _find_and_load
  File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 678, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/frontend/__init__.py", line 19, in <module>
    from homeassistant.components.http import HomeAssistantView
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/http/__init__.py", line 30, in <module>
    from .auth import auth_middleware
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 8, in <module>
    from aiohttp.web import middleware
ImportError: cannot import name 'middleware'
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component frontend
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for frontend: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.history. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/history.py", line 20, in <module>
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component history
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for history: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.device_tracker. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 27, in <module>
    from homeassistant.helpers.restore_state import async_get_last_state
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/helpers/restore_state.py", line 11, in <module>
    from homeassistant.components.history import get_states, last_recorder_run
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component device_tracker
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for device_tracker: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.automation. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/automation/__init__.py", line 21, in <module>
    from homeassistant.components import logbook
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/logbook.py", line 18, in <module>
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component automation
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for automation: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.tts. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/tts/__init__.py", line 24, in <module>
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component tts
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for tts: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Error during setup of component map
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
    result = yield from component.async_setup(hass, processed_config)
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/map.py", line 15, in async_setup
    yield from hass.components.frontend.async_register_built_in_panel(
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/loader.py", line 185, in __getattr__
    raise ImportError('Unable to load {}'.format(comp_name))
ImportError: Unable to load frontend
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.conversation. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/conversation.py", line 19, in <module>
    from homeassistant.components import http
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component conversation
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for conversation: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.light.hue. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/light/hue.py", line 26, in <module>
    from homeassistant.components.emulated_hue import ATTR_EMULATED_HUE_HIDDEN
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/emulated_hue/__init__.py", line 17, in <module>
    from homeassistant.components.http import REQUIREMENTS  # NOQA
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component light.hue
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.logbook. Make sure all dependencies are installed
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component logbook
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for logbook: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.http. Make sure all dependencies are installed
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component http
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for http: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.config. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/config/__init__.py", line 11, in <module>
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component config
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for config: Component not found.
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.camera. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/camera/__init__.py", line 31, in <module>
    from homeassistant.components.http import HomeAssistantView, KEY_AUTHENTICATED
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.loader] Unable to find component camera
2017-11-19 08:28:01 ERROR (MainThread) [homeassistant.setup] Setup failed for camera: Component not found.
2017-11-19 08:28:02 ERROR (SyncWorker_6) [homeassistant.components.zoneminder] Connection error logging into ZoneMinder
2017-11-19 08:28:02 ERROR (MainThread) [homeassistant.setup] Setup failed for zoneminder: Component failed to initialize.
2017-11-19 08:28:02 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.zoneminder. Setup failed for dependencies: zoneminder
2017-11-19 08:28:02 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.zoneminder: Could not setup all dependencies.
2017-11-19 08:28:02 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.zoneminder. Setup failed for dependencies: zoneminder
2017-11-19 08:28:02 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.zoneminder: Could not setup all dependencies.
2017-11-19 08:28:17 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.media_player. Make sure all dependencies are installed
  File "/home/server/.local/lib/python3.6/site-packages/homeassistant/components/media_player/__init__.py", line 21, in <module>
    from homeassistant.components.http import KEY_AUTHENTICATED, HomeAssistantView
2017-11-19 08:28:17 ERROR (MainThread) [homeassistant.loader] Unable to find component media_player
2017-11-19 08:28:17 ERROR (MainThread) [homeassistant.setup] Setup failed for media_player: Component not found.
What am I missing? Thanks!
–Databoy2k
The middleware error has been reported by others too, which includes a hack to get it working.
One possible fix is to clean out the deps/ folder from your Home Assistant directory, and restart. The expectation is that’ll clear this up.
Thanks for your help. It looks like it’s up and running again after cleaning out the deps/ folder from .homeassistant in my user’s home. The middleware hack only broke it further (the service wouldn’t start).
It seems that something is broken, though. Now I’m getting errors for Zoneminder addin:
2017-11-19 13:21:24 ERROR (SyncWorker_12) [homeassistant.components.zoneminder] Connection error logging into ZoneMinder
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Setup failed for zoneminder: Component failed to initialize.
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of sensor.zoneminder. Setup failed for dependencies: zoneminder
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.zoneminder: Could not setup all dependencies.
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of camera.zoneminder. Setup failed for dependencies: zoneminder
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform camera.zoneminder: Could not setup all dependencies.
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.zoneminder. Setup failed for dependencies: zoneminder
2017-11-19 13:21:24 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.zoneminder: Could not setup all dependencies.
Does Zoneminder have issues in this new version?
Try restarting again, it may need to install the zoneminder package.
In theory just removing any sub-folder starting aiohttp will also clear it.
Thanks for responding, but that didn’t get it working. I even tried deleting the entire /deps directory again and re-loading. Still no dice.
that connection error is troubling me. Last version I used 127.0.0.1 as my host (the server is also running ZM). Maybe there’s an issue in hostname rectification?
I’m about to log into the discord chat, but if I don’t respond that it’s solved I’d still appreciate troubleshooting tips from anyone who has an idea of the problem.
Last comment worked for me: HA 0.60.0 - bare install on stretch lite
