Hi
I’m running Home Assistant Core installed with pip under Debian Bullseye. After upgrading to 2021.4.2 with
pip install --user --upgrade homeassistant homeassistant-cli home-assistant-frontend
I still had an old version of the frontend (I was looking forward to testing the automation traces, but did not see any; eventually I realized the fronted didn’t upgrade). The version in pip was updated, but the deps
folder still had an old version. The issue was resolved after I removed the whole deps
folder and restarted.
Is upgrading via pip
generally supported? Should deps
get upgrades automatically also in this case?
Is it sensible to just remove deps
in case of issues? At least it seems to have the advantage that old integrations (that I removed via the frontend) also get cleaned up.
Thanks, Andreas
