Dependency on AIOHTTP
I’m trying to install Homeassistant on an Android Tablet. I’m facing a problem that looks impossible to fix:
When I use Python 3.11, I get a compilation error :
arm-linux-androideabi-clang -mfloat-abi=softfp -mfpu=vfpv3-d16 -DNDEBUG -g -fwrapv -O3 -Wall -march=armv7-a -mfpu=neon -mfloat-abi=softfp -mthumb -fstack-protector-strong -O3 -march=armv7-a -mfpu=neon -mfloat-abi=softfp -mthumb -fstack-protector-strong -O3 -fPIC -I/data/data/com.termux/files/home/hass/include -I/data/data/com.termux/files/usr/include/python3.11 -c aiohttp/_websocket.c -o build/temp.linux-armv7l-cpython-311/aiohttp/_websocket.o
aiohttp/_websocket.c:198:12: fatal error: 'longintrepr.h' file not found       #include "longintrepr.h"
 ^~~~~~~~~~~~~~~              1 error generated.
error: command '/data/data/com.termux/files/usr/bin/arm-linux-androideabi-clang' failed with exit code 1
To solve this, I have seen that I should use a file requirements.txt where I can specify the versions that I want.
The above error about 'longintrepr.h’ can be fixed by using:
aiohttp==3.8.2
yarl==1.8.1
frozenlist==1.3.1
So finally, I used the following requirements.txt file:
(hass) ~ $ cat requirements.txt
aiohttp==3.8.2
aiosignal==1.3.1
async-timeout==4.0.2
attrs==21.2.0
certifi==2022.9.24
charset-normalizer==2.1.1
docopt==0.6.2
frozenlist==1.3.1
homeassistant==2022.11.4
idna==3.4
multidict==5.2.0
numpy==1.23.4
pipreqs==0.4.11
requests==2.28.1
tzdata==2022.6
urllib3==1.26.13
wheel==0.38.4
yarg==0.1.9
yarl==1.8.1
Unfortunately, it is not working because there is a version conflict:
 The conflict is caused by:
   The user requested aiohttp==3.8.2
   homeassistant 2022.11.4 depends on aiohttp==3.8.1
Do you think that we will have soon a version of homeassistant depending on aiohttp 3.8.2?
Thank you
Maybe that my post was not at the right place. Do you know who could help to give information about the dependency on AIOHTTP?
Thank you
sudo apt-get install python-dev
or for Alpine
apk add python-dev
