I can install zigbee2mqtt and dev version of it on same instance , but only one works.
but i need 2 different to work with livolo switches in one and other zigbee devices in separeted channel.
any ideas ?
Let me guess, you try to run two times the zigbee2mqtt add-on ?
yes, i have 2 zigbee usb stick, and second instance of zigbee2mqtt just not start.
2 times the add-on will not work. They have the same docker signature.
You have some options :
1/ Use one with zigbee2mqtt, and one with zha
2/ Use one with with the add-on, and use portainer to install the normal docker zigbee2mqtt container
3/ If you use HA Supervised, install zigbee2mqtt on bare metal for one, use the add-on for the second.
Don’t forget to have separate panid and channels on each instance !
ty i will try
