Deploy ustvgo dashboard with channel cards and update links using YAML dashboards
just started working on this automation for creating dashboards with all ustvgo available channels as cards, And a ‘scheduling’ setting which will refresh the links in the cards every X minutes since the ustvgo links are only active for ~4 hours
ustvgo-homeassistant-dashboard
the script will:
  • fetch m3u links if set
  • use jinja2 on yaml templates
  • add dashboard block to configuration.yaml
  • create dashboard.yaml if does not exist
  • add a card for every channel fetched
would really appreciate some feedback and comments on possible next steps?
thanks!
Awesome work! Is it possible to change the .m3u file for another one? Is the script going to fetch the m3u file flawlessly? Thanks
