I currently use Ansible to deploy all of my servers at home, I find it makes it easier if i mess up some configuration its easy to rollback or to rebuild if required.
I am writing up an Ansible playbook for deploying hassio, so far i can deploy hassio onto centOS, download my config from github etc.
How can I install the addons for Hassio via a command line or some other way with ansible?
Has anyone made progress figuring out an ansible installation? I’m additionally confused by the distinction between installing “Home Assistant” via Docker and “hass.io”, which appears to want to be installed by running a bash script.
Ok I have finally got something working, after a lot of messing about and errors along the way I have a fully functioning Ansible Hassio role that will deploy hassio as expected.
I have also added a module that allows you to install / remove addons, this is not yet tested and im hoping to get that tested over the next few days.
