Hi hope I posted to the correct thread
I recently got an depreci on Google API key
"The 'api_key' option (with value 'XXsafdsgjkgrXX') is deprecated, please remove it from your configuration...."
I un-comment in VSC… Config check shows up fine, I go and restart HA and it keeps hanging. Luckily I am able to Samba in to turn the API key back on. It reboots fine, any thoughts?
I’m up to date on 104.x just did today 1/18/2020 with Hassio Pi 3b+… nothing in the logs
Hi thanks David.
I have looked and I guess I need to have a JSON now.
I don’t see an example of the format except what’s stated in the docs
service_account: !include SERVICE_ACCOUNT.JSON
service_account
(map)(Optional)
Service account information. You can use an include statement with your downloaded JSON file, enter data here directly or use secrets file to populate.
private_key
(string)(Required)
Private key in PEM format
client_email
string)(Required)
Not messed with this much.
Have you David?
Has anyone ran into this deprecation? and care to share an example?
