Thx - I don’t see ability to add external url to that UI screen - I think it may be because I added some other config options manually to yaml which block UI control. I’ll keep digging. Thanks
Unfortunately, this did not work for me. TTS still does not function on my Homepod Minis after updating to HA 2022.5.X
I had removed “base_url” from my “configuration.yaml” and verified that my external URL was my duckdns URL in the UI under the Network settings. I have it automatically finding my internal URL.
Anyone else know what may be going on? My TTS setup looks like this…
I have the correct configuration (as requested), https for external and http for internal, but still my Bose SoundTouch cant play TTS neither Local Media (on the device display it spin as if it is loading but then it doesnt load)
Logs do not shows any error (error was present when i had both external and internal in https), so i guess HA correctly sends the files to the device, but then the device is unable to play them
any suggestion?
I solved this by configuring external and internal url from the UI instead that from the configuration.yaml
In case someone else is having this experience, when using Google Cast devices, I had to set both of the “Internet” and “Local Network” settings under Settings/Network to my externally-visible URL. Without that, the (local) devices would attempt to resolve using the local network URL and would fail. Only when I set the “Local Network” setting to my externally-visible URL did the devices play correctly.
