Sounds like a good idea. Currently I have no better approach. So let’s try.
i don´t know where the failure is. The modified automation will not load with the following sequence at line 879:
sequence:
- if:
- condition: template
value_template: '{{expand(blind)|map(attribute=''entity_id'')|list|count > 1 }}'
then:
- repeat:
for_each: '{{ expand(blind)|map(attribute=''entity_id'')|list }}'
sequence:
- delay: 00:00:{{ (range(1, 3)|random|int) }}
- service: cover.open_cover
data: {}
entity_id: "{{ repeat.item }}"
else:
data: {}
entity_id: blind
- stop: Stop the automation
Can you try
value_template: "{{expand(blind)|map(attribute='entity_id')|list|count > 1 }}"
and
for_each: "{{ expand(blind)|map(attribute='entity_id')|list }}"
the result is:
Message malformed: expected a dictionary for dictionary value @ data['action'][1]['choose'][0]['sequence'][0]['choose'][1]['sequence'][0]['then'][0]['repeat']
@Gifford47: I uploaded a new version. Can you please test this one?
Cover groups are handled for opening, closing, shading and also ventilate. But I’m not sure if ventilation makes sense if we have a group cause every blind of the group is driving to ventilate_position as we don’t know which blind (window) is connected to the window sensor. Any ideas for this?
Maybe my changes are useful for some else.
Because of I have a lot of externel blinds the new open and close position feature brought my blinds in a wrong position. They were not fully opened (because of the position is calculatet based on the driving time) and goining to the close position of 0% leaves the slats of my blinds opened.
Going to the shading position means the same. The slats are still in the wrong position and the sun came in.
Thats why I replaced the open an close position (set_cover_position) with the cover_open an cover_close service.
I also added an input for a “shading tilt position”.
Thanks a lot for this geat Blueprint. It saves me a lot of time.
input:
# inputs we need for everything
blind:
description: "Which roller shutter should be automated?"
selector:
entity:
filter:
- domain:
- cover
# inputs only for shading
auto_shading:
name: "🕶️ Auto Shading"
description: "Enable the auto shading function?\n\n`Shading`"
default: true
selector:
boolean: {}
shading_blinds_position:
name: "🕶️ Shading position"
description: "To which position should the shutter be moved for shading?\n\n`Shading`"
default: 25
selector:
number:
min: 0.0
max: 100.0
unit_of_measurement: "%"
shading_tilt_position:
name: Shading tilt position
description: "To which tilt position should the cover be moved for shading?\n\n`Shading`"
default: 50
selector:
number:
min: 0
max: 100
mode: restart
max_exceeded: silent
variables:
blind: !input blind
brightness_sensor: !input brightness_sensor
shading_sun_sensor: !input shading_sun_sensor
shading_outdoor_temperatur_sensor: !input shading_outdoor_temperatur_sensor
shading_outdoor_temperatur_sensor2: !input shading_outdoor_temperatur_sensor2
shading_azimuth_in: !input shading_azimuth_in
shading_azimuth_out: !input shading_azimuth_out
shading_elevation_min: !input shading_elevation_min
shading_elevation_max: !input shading_elevation_max
shading_min_temperatur: !input shading_min_temperatur
shading_min_temperatur2: !input shading_min_temperatur2
shading_blinds_position: !input shading_blinds_position
shading_tilt_position: !input shading_tilt_position
shading_sun_brightness_in: !input shading_sun_brightness_in
shading_sun_brightness_out: !input shading_sun_brightness_out
shading_waitingtime: !input shading_waitingtime
shading_waitingtime_out: !input shading_waitingtime_out
auto_shading: !input auto_shading
forecast_sensor: !input forecast_sensor
forecast_temp: !input forecast_temp
weather_conditions: !input weather_conditions
temporary_disable_shading: !input temporary_disable_shading
# triggers for shading in
- platform: numeric_state
entity_id: !input shading_outdoor_temperatur_sensor
above: !input shading_min_temperatur
entity_id: !input shading_outdoor_temperatur_sensor2
above: !input shading_min_temperatur2
entity_id: !input brightness_sensor
above: !input shading_sun_brightness_in
entity_id: !input shading_sun_sensor
attribute: elevation
above: !input shading_elevation_min
attribute: azimuth
above: !input shading_azimuth_in
below: !input shading_azimuth_out
above: !input forecast_temp
- platform: state
entity_id: !input temporary_disable_shading
to: "off"
for: '00:00:05' # we need a small delay cause temporary_disable_shading also triggers shading out
# triggers for shading out
below: !input shading_min_temperatur
below: !input shading_min_temperatur2
below: !input shading_sun_brightness_out
above: !input shading_elevation_max
attribute: azimuth
above: !input shading_azimuth_out
below: !input shading_elevation_min
- platform: state
to: "off"
for: '00:00:02' # we need a small delay cause temporary_disable_shading also triggers shading in
# trigger for opening blind
entity_id: !input brightness_sensor2
above: !input brightness_up
for: '00:00:03'
- platform: time
at: !input time_up_late
- platform: time
at: !input time_up_early
- platform: time
at: !input time_up_early_non_workday
- platform: state
entity_id: !input resident
to: "off"
for: '00:00:05'
# trigger for closing blind
below: !input brightness_down
- platform: time
at: !input time_down_early
- platform: time
at: !input time_down_late
- platform: state
entity_id: !input window_sensor
to: "off"
- platform: state
to: "on"
# trigger for ventilate
- platform: state
to: "on"
condition:
- or:
value_template: "{{ auto_shading }}"
value_template: "{{ auto_up }}"
value_template: "{{ auto_down }}"
## we have to call a service for forecast due to HA changes
- if:
value_template: "{{ (forecast_sensor != [] ) }}"
then:
- service: weather.get_forecasts
entity_id: !input forecast_sensor
type: daily
response_variable: forecast
- choose:
- alias: "Check and perform shading in or blinds up"
conditions:
- or:
- or:
# Check if we have a trigger for shading in
- condition: trigger
# Check if we have a trigger for blinds up
sequence:
- choose:
- alias: "Checking for shading in"
conditions:
- and: # Check if we want to perform shading in
value_template: "{{ ( (temporary_disable_shading == [] ) or (is_state(temporary_disable_shading, 'off')) ) }}"
value_template: "{{ now() >= today_at(time_up_early) }}"
value_template: "{{ now() <= today_at(time_down_late) + timedelta(seconds = 5) }}"
value_template: "{{ ( (shading_outdoor_temperatur_sensor == [] ) or (states(shading_outdoor_temperatur_sensor) | int(default=shading_min_temperatur) >= shading_min_temperatur) ) }}"
value_template: "{{ ( (shading_outdoor_temperatur_sensor2 == [] ) or (states(shading_outdoor_temperatur_sensor2) | int(default=shading_min_temperatur2) >= shading_min_temperatur2) ) }}"
value_template: "{{ ( (brightness_sensor == [] ) or (states(brightness_sensor) | int(default=shading_sun_brightness_in) >= shading_sun_brightness_in) ) }}"
value_template: "{{ state_attr(shading_sun_sensor, 'azimuth') >= shading_azimuth_in and state_attr(shading_sun_sensor, 'azimuth') <= shading_azimuth_out }}"
value_template: "{{ state_attr(shading_sun_sensor, 'elevation') >= shading_elevation_min and state_attr(shading_sun_sensor, 'elevation') <= shading_elevation_max }}"
value_template: "{{ state_attr(blind, 'current_position') | int(default=101) > shading_blinds_position }}"
value_template: "{{ ( (resident == [] ) or (is_state(resident, 'off')) ) }}"
- or:
value_template: "{{ ( forecast_sensor == [] ) and (shading_outdoor_temperatur_sensor == [] ) }}"
value_template: "{{ ( forecast_sensor != [] ) and ( forecast.forecast[0].temperature | int(default=forecast_temp) >= forecast_temp ) }}"
value_template: "{{ (shading_outdoor_temperatur_sensor != [] ) and (states(shading_outdoor_temperatur_sensor) | int(default=forecast_temp) >= forecast_temp) }}"
value_template: "{{ ( forecast_sensor == [] ) or (states(forecast_sensor) in weather_conditions) }}"
sequence:
# we are ready for shading in
- if: # check if blind is higher than ventilate position. In this case we consider blind position like open and therefor we want to use the delay timer
value_template: "{{ state_attr(blind, 'current_position') | int(default=101) > ventilate_position }}"
- not:
then:
- alias: "Wait the number of seconds set in shading_waitingtime"
delay:
seconds: !input shading_waitingtime
else:
# seems that blinds are lower or at ventilate position. So we consider blinds as closed and directly drive to shading position
- alias: "Wait 1-5 random seconds to prevent sending to many commands to blinds at same time"
delay: '00:00:{{ (range(1, 3)|random|int) }}'
- alias: "Moving the blind to cover position"
service: cover.set_cover_position
entity_id: !input blind
- alias: "Set cover tilt position for shading"
service: cover.set_cover_tilt_position
- stop: "Stop the automation"
- alias: "Check for opening"
conditions:
- or: # Check if the trigger is for normal blind opening
- or:
value_template: "{{ state_attr(blind, 'current_position') | int(default=101) == ventilate_position }}"
value_template: "{{ (state_attr(blind, 'current_position') | int(default=110) <= closed_position + position_tolerance) and (state_attr(blind, 'current_position') | int(default=110) >= closed_position - position_tolerance)}}"
# Now we have to check different opening scenarios
- condition: or
conditions:
- alias: "Blinds - opening - up late reached "
and:
value_template: "{{ now() >= today_at(time_up_late) }}"
- or:
value_template: "{{ now() <= today_at(time_down_early) + timedelta(seconds = 5) }}"
- alias: "Blinds - opening - up early reached and brightness above minimum"
and:
- or:
- and:
value_template: "{{ (workday_sensor == [] or (is_state(workday_sensor, 'on')) ) }}"
- and:
value_template: "{{ (workday_sensor == [] ) or (is_state(workday_sensor, 'off')) }}"
value_template: "{{ now() >= today_at(time_up_early_non_workday) }}"
value_template: "{{ now() <= today_at(time_up_late) + timedelta(seconds = 5) }}"
- or:
value_template: "{{ ( (brightness_sensor2 == []) and (brightness_sensor == []) ) }}"
value_template: "{{ ( (brightness_sensor2 != []) and (states(brightness_sensor2) | int(default=brightness_up) >= brightness_up) ) }}"
value_template: "{{ ( (brightness_sensor2 == [] and brightness_sensor != []) and (states(brightness_sensor) | int(default=brightness_up) >= brightness_up) ) }}"
sequence:
# ok, we can open the blind
- delay: '00:00:{{ (range(1, 3)|random|int) }}'
# - service: cover.set_cover_position
# data:
# position: !input open_position
default:
- alias: "Check and perform shading out"
conditions:
# - condition: trigger
# id: "t_o_2"
- or:
value_template: "{{ state_attr(blind, 'current_position') | int(default=101) == shading_blinds_position }}"
sequence:
- if:
# if sun is outside of shading window (azimuth or elevation) we immedately stop shading
- and:
- not:
then:
- alias: "Wait the number of seconds set in shading_waitingtime_out"
delay:
seconds: !input shading_waitingtime_out
- if:
value_template: "{{ ( (window_sensor != []) and (is_state(window_sensor, 'on') ) ) }}"
value_template: "{{ auto_ventilate }}"
then:
- alias: "Moving the blind to ventilate position"
position: !input ventilate_position
else:
- alias: Moving the blind to open position
#service: cover.set_cover_position
#data:
#position: !input open_position
- alias: "Check for closing blind"
conditions:
- or:
- or:
value_template: "{{ ( (adv_blind == []) or (is_state(adv_blind, 'off')) ) }}"
- or:
# Check if we have a trigger for blind down
# ## check to allow a window but a door only if window_sensor not open - we want protection
value_template: "{{ ( ( door == 'false' ) or ( (door == 'true') and (window_sensor == []) ) or ( (door == 'true') and (window_sensor != []) and (is_state(window_sensor, 'off') ) ) ) }}"
- or:
value_template: "{{ (state_attr(blind, 'current_position') | int(default=110) <= open_position + position_tolerance) and (state_attr(blind, 'current_position') | int(default=110) >= open_position - position_tolerance)}}"
- or:
- alias: Blinds - closing - down late reached
and:
value_template: "{{ now() >= today_at(time_down_late) }}"
- alias: Blinds - closing - down early reached and brightness below minimum
and:
value_template: "{{ now() >= today_at(time_down_early) }}"
- or:
value_template: "{{ ( (brightness_sensor == [] ) and (brightness_sensor2 == [] ) ) }}"
value_template: "{{ ( (brightness_sensor != [] ) and (states(brightness_sensor) | int(default=brightness_down) <= brightness_down) ) }}"
value_template: "{{ ( (brightness_sensor2 != [] ) and (states(brightness_sensor2) | int(default=brightness_down) <= brightness_down) ) }}"
- alias: Blinds - closing - due to resident goes sleeping
and:
value_template: "{{ ( (resident != [] ) and (is_state(resident, 'on')) ) }}"
- alias: Blinds - closing after ventilate
and:
value_template: '{{ (window_sensor != [] ) and (states(window_sensor) == ''off'') }}'
sequence:
- if:
- not:
then:
- if:
then:
else:
#- service: cover.set_cover_position
#data:
#position: !input closed_position
- service: cover.close_cover
- alias: Window sensor - opened
conditions:
value_template: "{{ ( (window_sensor != []) and (is_state(window_sensor, 'on')) ) }}"
sequence:
default:
- stop: "Stopping the automation - reset"
@kreuzundkwer: Maybe it’s an idea to check if open_position is 100 and in this case calls cover.open_cover instead of cover.set_cover_position (same for closed_position = 0 and cover.close_cover)?
If so, adding shading_tilt_position would be no additional effort (as I could copy your code)
Yes, thats seems to be a comfortable way to implement this option.
Do your blind, which are able to tilt, have an attribute current_tilt_position? Cause I need to implement a check if a blind is able to perform cover.set_cover_tilt_position. Just calling the service will always create an error.
Yes, they do. There is a special communication object wich gives back the current position.
I am relatively new to HA and last week I imported the blueprint and created automations.
Unfortunately, they don’t work for me.
Either I’m misunderstanding something in the config or the log or I’m running into a bug.
I’m not even shadowing yet, it’s winter here
Unfortunately, closing in the evening and opening in the morning doesn’t work for me.
I see that the automation is executed but then runs directly to a stop.
I use the Christmas mode to close the blinds automatically only when nobody is at home.
I need your config to get an idea what could go wrong.
And, if possible, a screenshot of a trace would be nice. I explained it a little bit here Extensive roller shutter control including shading (brightness, sun position, temperature, forecast) - #40 by Eimeel
Ok, has been implemented. But as my blinds are not able to tilt, I can’t check it.
This is the configuration of one of my roller blinds.
While we are at home, the blinds should not be raised in the morning or lowered in the evening. But we were still at home over New Year’s Eve and unfortunately nothing moved.
Unfortunately, I can no longer access the schedule for 31.12/01.01 via the ui.
Ok, seems to be ok (so far).
But I’m a little bit confused.
You don’t want the blind to move if you are home. Ok. And the automation didn’t moved while you have been at home over New Year’s Eve? Or is there a “not” missing?
Nevertheless let’s clarify a little bit:
As I wrote in the documentation for adv_blind:
If this Sensor (input_boolean or binary_sensor) is set to TRUE, the shutter will not close automatically
The check is:
- "{{ ( (adv_blind == []) or (is_state(adv_blind, 'off')) ) }}"
So if you define adv_blind, the automation will only close the blind if adv_blind is off (false).
And I guess group.anwesenheit_family will be home or not_home. So this check can never be passed.
I first thought I could easilier expand the check. Following your case I just need to check as well for “home”. But the next one will need to check for “not_home” or something different. So I leave it as it is, sorry. Meaning you need an additional sensor for your usecase.
But I don’t understand why the blind is not mowing in the morning. Cause you didn’t define resident - which most likely would have explained it.
Can you have a look at the automation traces what happend today at 05:45?
You’re right, of course, there’s a “not” missing. We weren’t at home over New Year’s Eve.
But as you wrote, it can’t work if the only condition is “true”. I’ll have to see how I can create a sensor that is set to “true” or “false” when the status of group.anwesenheit_family changes.
Unfortunately I don’t have any traces from this morning, probably because I restarted HA at noon today.
Do I understand correctly that the christmas mode only applies to closing and that I also have to define the new dummy sensor to be created as a resident if I only want automation in the event of absence?
Yes, you are correct. This is more or less due to the fact that my purpose for the blueprint is not a “only run when no one is home”-automation
The sensor is quite easy. You can use something like:
platform: state
entity_id: group.anwesenheit_family
service_template: >
{% if is_state('group.anwesenheit_family', 'not_home') %}
input_boolean.turn_off
{% else %}
input_boolean.turn_on
{% endif %}
entity_id: input_boolean.my_boolean
I don’t get it…
My code is
#Anwesenheit
- trigger:
platform: state
service_template: >
{% if is_state('group.anwesenheit_family','not_home') %} input_boolean.turn_off {% else %} input_boolean.turn_on {% endif %}
entity_id: input_boolean.anwesenheit
Studio Code server shows no error but yaml check says:
It’s just a stub You need to create a real automation.
oh me idiot, I wanted to enter the whole thing in sensor.yaml.
