Hi!
Since last month I am getting this warning in Home Assistant:
Deprecated
payload_template
option used in MQTT publish action call to topicflamingo/weather
from payload templateunknown
. Use thepayload
option instead. In automations templates are supported natively. Update the automation or script to use thepayload
option instead and restart Home Assistant to fix this issue.
I checked the documentation but I am completely clueless about how to fix this, I am not using any payload_template
in my config:
light:
- name: "flamingo"
command_topic: "flamingo/power"
state_topic: "flamingo/state"
brightness_state_topic: "flamingo/brightness/state"
brightness_command_topic: "flamingo/brightness/set"
payload_on: "on"
payload_off: "off"
retain: false
I would be thankful for any clue.
