Deprecated sintax in HACS module in 2021.9 version
In past I used unifi, AdGuard and ESPHome installing them with HACS; now I alreadey removed thesse modules! no any folder found in custom_components!
today I installed 2021.9 version and I found these warning:
21-09-07 06:35:52 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-09-07 06:35:53 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-09-07 06:35:53 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of ESPHome
21-09-07 06:35:54 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of AdGuard Home
21-09-07 06:35:55 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot' is deprecated, 'backup' should be used instead. Please report this to the maintainer of UniFi Controller
21-09-07 06:35:55 WARNING (MainThread) [supervisor.addons.validate] Add-on config 'snapshot_exclude' is deprecated, 'backup_exclude' should be used instead. Please report this to the maintainer of ESPHome
How I can erase these warnings? there is some file in filesystem of my HASSOS?
No you did not.
They are all addons. HACS has never supported addons.
Ignore the warnings. It something for the developers of those addons to fix. Iā€™m sure they know by now.
You would see the warnings even if you had never installed the addons.
