Description Syntax help please
I noticed there is now a a description label that can be added to yaml texts , so a description can be added in , in automations.yaml.
What are the rules for using this, ie, indent from column 1.
At the moment I’m doing a complete fresh install, as I have problems from the last two updates .
especially with device tracking. Devices are tracked and shown as either home or away in Lovelace, but automations which have previously worked now fail, but can be manually controlled from lovelace GUI.
Hence the description syntax question so can make a note what has been changed, in section of the original automations.yaml scripts that did work for a couple of years
thanks
