Hello! There is yet another dynamic dns service. I’m not in any way affiliated with it, but it is free (as of dec’ 2022 no paid plans), it has ipv4 and ipv6 support, rest api, A (ipv4) and AAAA (ipv6) records with TTL 60, and those records can be updated separately. It also has TXT support and let’s encrypt bot, but that’s another story, because it is easier to use in beatiful NGINX proxy manager addon GitHub - hassio-addons/addon-nginx-proxy-manager: Nginx Proxy Manager - Home Assistant Community Add-ons (it has deSEC support, btw).
So I decided to “make” an integration for. Since I have a little below 0 knowledge of python and HA, I just copy-pasted freedns integration and slightly modified it to work with deSEC dynamic dns.
Config stored in configuration.yaml and I need help making it ADR-0010 compliant architecture/0010-integration-configuration.md at 2017fdae15d48f287f2398e3243a91ec7a34b161 · home-assistant/architecture · GitHub
Here is the repo GitHub - JugglerLKR/desec_dedyn: Home Assistant deSEC dynamic dns integration (dedyn.io)
To try it, you have to add lines to configuration.yaml (as in readme), create desec_dedyn directory in your config/custom_components, put two files from repo and restart.
I know it is very ugly, but it works, this is why I need someone to make it better.
