Designing a premium 24” wall-mounted touchscreen for Home Assistant - Dell P2424HT vs iiyama T2452MSC (Raspberry Pi, DDC/CI, long-term experience)
Hi everyone,
I’m currently designing what I hope will become the main wall-mounted control panel for my home.
This isn’t intended to be “just another dashboard on the wall”. I’m trying to build something closer to a premium integrated home display that also happens to be a Home Assistant control panel.
The project is still in the design phase, so I’m not asking “which monitor is best?”. I already have a decision framework and I’m trying to eliminate unknown risks before buying a test unit.
Current architecture:
• Home Assistant runs on my NAS.
• Raspberry Pi 5 (Ethernet) only acts as the kiosk client.
• Chromium in kiosk mode.
• Immich provides family photos.
• I’m planning to build a lightweight custom “Home Display” web app (photos, clock, weather, solar production, battery, alarm, etc.).
• The full Home Assistant dashboard only appears when someone interacts with the display.
The panel will operate in four states:
A. Screen in standby.
B. Presence detected → wake monitor → Home Display.
C. User touches the screen → Home Assistant dashboard.
D. No presence for a while → return to Home Display → back to standby.
After several weeks of research I’ve narrowed the monitor choice down to:
• Dell P2424HT
• iiyama T2452MSC-B2AG (or T2438MSC-B2 if you have direct experience)
I’m specifically looking for hands-on experience with these exact monitors (or extremely close models), ideally with Raspberry Pi OS or Linux.
The things I’m trying to validate are:
• Does DDC/CI work reliably?
• Can brightness be controlled with ddcutil?
• Can the monitor reliably enter and exit standby?
• Does the USB touchscreen recover correctly after standby?
• Any firmware quirks?
• Any long-term reliability issues after months or years?
• Image quality for displaying photos most of the day.
• Anti-glare performance in a bright hallway.
• Did you have to do anything non-obvious to make DDC/CI or DPMS work correctly?
I’m not looking for generic recommendations or “I’d buy a tablet instead”. I’m specifically interested in eliminating unknown risks before purchasing the first test unit.
Finally, if you’ve built a similar permanent wall panel, what would you do differently today?
I’m especially interested in the mistakes you only discovered after living with it for months or years.
Thanks!
I’m also very interested in exactly the same requirements. Have you already found or tested a solution?
I’ve been running a wall-mounted display in my kitchen for many years — not the exact hardware you’re evaluating, but some of my experience with standby/DDC behavior may still be useful.
I started with a Samsung display as an experiment to see if my family would actually use it. It’s not a touchscreen, just a plain monitor plugged into a Raspberry Pi 4. I later swapped in a Dell monitor (different model than the P2424HT you’re considering) when the Samsung’s power supply died from heat.
On your specific questions, based on my Dell + Pi 4 setup running TouchKIO:
  • DDC/CI reliability: Since moving to TouchKIO, I can turn the screen on and off reliably.
  • Brightness via ddcutil: Haven’t tried it.
  • Standby enter/exit: Yes, reliably. I believe the TouchKIO script turns off the HDMI interface rather than using true monitor standby.
  • Touch recovery after standby: No touch on my unit, so I can’t speak to this.
  • Firmware quirks: None that I’ve noticed.
  • Long-term reliability: My original Samsung developed heat problems, but that was from running it on constantly inside an enclosed 1x4 box with little ventilation — not a monitor defect.
  • Image quality for photos: No issues.
  • Anti-glare in a bright hallway: Direct sun at the wrong angle does wash it out somewhat when I’m sitting at a bad angle, but I don’t think there’s a real fix for that regardless of panel.
  • Non-obvious setup steps for DDC/CI or DPMS: Just followed TouchKIO’s setup docs (GitHub - leukipp/touchkio: Home Assistant Touch Panel Kiosk application for a Linux device (e.g. Raspberry Pi) with Touch Display. · GitHub) and it worked. I recall having to adjust HDMI power settings in the boot params.
One lesson from living with this setup for years: heat and enclosure airflow matter more than I expected — my first power supply failure was from running the display 24/7 in a sealed box. I’m now looking at a Waveshare display for my next revision since it mounts the Pi and draws power directly from the monitor, solving the clearance/heat issue I ran into with the Dell in my old 1x4 enclosure.
Hi, I’m using this to control the display from a few RPi’s
"echo 0 | sudo tee /sys/class/backlight/rpi_backlight/bl_power"
Even though using dark dashboards, on a wall tablet in the kitchen white was the better choice.
