Hello @jcastro. Do you have the big fully controller with display or only the small one?
Could you maybe DM me your ESPHome config? I cant get the logging working.
Also my display isnt working anymore on the fully controller when my passthrough is connected. @Mahko_Mahko do you maybe have an idea about this?
Controller and ESP32
The first one is my used controller. This is my used ESP32
Config
esphome:
friendly_name: Standing Desk
on_boot:
priority: -100.0
then:
#Request a desk height update after boot.
- delay: 5s
- switch.turn_on: wake_desk_and_get_height
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERY_VERBOSE
# Enable Home Assistant API
api:
encryption:
key: "lBXwa0ZuqNLMwW4rHZC0PhX7yCSeXnKencdECSKA1wY="
ota:
password: "359fa6d122acb1d2dabc5366276edc66"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Standing-Desk Fallback Hotspot"
password: "gi4UyEI3xG5D"
captive_portal:
external_components:
#Fetch ssieb's custom component# https://github.com/ssieb/custom_components/tree/master/components/desky
- source:
type: git
url: https://github.com/ssieb/custom_components
components: [ desky ]
uart:
- id: desk_uart
baud_rate: 9600
rx_pin: 1
##You can uncomment the debug section below to see UART messages.
debug:
direction: BOTH
dummy_receiver: true
after:
bytes: 9
- lambda: UARTDebug::log_int(direction, bytes, ',');
desky:
##Uncomment this block to use Ssieb's move_to componet function.
# up:
# number: 4 #D2
# inverted: true
# down:
# number: 5 #D1
# inverted: true
# stopping_distance: 15 # optional distance from target to turn off moving, default 15
height: # Sensor publishing the current height
accuracy_decimals: 1
unit_of_measurement: cm
#any other sensor options
filters:
- delta: 0.05 #Only send values to HA if they change
- throttle: 200ms #Limit values sent to Ha to 5 per sec.
- multiply: 0.1 #convert from mm to cm
on_value:
then:
#If the value changes, then the desk is moving
- binary_sensor.template.publish:
state: ON
- delay: 300ms
#Assume it's stopped moving if no height changes after a short time.
state: Off
binary_sensor:
name: "Desky Is Moving"
filters:
- delayed_off: 400ms
#If the desk isn't moving for a bit we better turn off attempts at movement. It's like poor man's collision detection?
on_release:
then:
- button.press: desky_stop_desk
button:
#Stop movement
on_press:
then:
- switch.turn_off: raise_desk
- switch.turn_off: lower_desk
#Move to function
name: Go To Desky Height x
on_press:
then:
##Option 1: Uncomment to use Ssieb's move_to componet functions
# - lambda: id(my_desky).move_to(id(desky_target_height).state*10);
##Option 2: Uncomment to use Mahko's lambda alternative
#Check if we need to move desk up or down from current position
if:
#Current height is more than target height, then move desk down
lambda: |-
return id(desky_target_height).state < id(desky_height).state;
then:
- switch.turn_on: lower_desk
- wait_until:
#Run until the difference between current and target state is < stopping distance
lambda: return abs((id(desky_height).state - (id(desky_target_height).state)))<(id(stopping_distance_cm).state);
else:
#Current height is less than target height, move desk up
- switch.turn_on: raise_desk
- wait_until:
#Run until the difference between current and target state is <0.3cm
number:
#Target Height ("Move desk to height x").
#You should probably limit the range you can move the desk to to within the limits you've set via the control panel, perhaps offset a little within the range.
#Sending commands higher/lower than this may cause error messages and require desk reset (or worse).
name: "Desky Target Height"
optimistic: true
min_value: 80
max_value: 130.0
step: 0.1
#Offset correction - Adjust until you get the best accuracy.
#The desk keeps moving for a little while after the up/down pins are released and we try to account for this.
#1.5cm was about right on mine
name: "Desky Stopping Distance cm"
optimistic: true
min_value: 0
max_value: 2
step: 0.1
restore_value: true
initial_value: 1.5
#Define some preset heights.
#You can freely define as many adjustable presets as you like.
#These are all seperate/independant of what you've set via the control panel (we can't retrieve them currently).
#Standing Height #1 - Set a standing height.
name: "Desky Standing Height 1"
optimistic: true
#Limit the range
min_value: 120
max_value: 130
step: 0.1
restore_value: true
initial_value: 124
#Sitting Height #1 - Set a sitting height. This is independant of what you've set via the control panel.
name: "Desky Sitting Height 1"
optimistic: true
#Limit the range
min_value: 79.7
max_value: 82
step: 0.1
restore_value: true
initial_value: 79.9
switch:
#wake up ther desk and request it sends its height
- platform: gpio
name: "Request Desk Height"
pin:
number: GPIO18
inverted: true
on_turn_on:
- delay: 100ms
- switch.turn_off: wake_desk_and_get_height
#Raise the desk
- platform: gpio
pin:
number: GPIO21
# mode: INPUT_PULLUP
inverted: true
interlock: lower_desk
on_turn_on:
#Auto off after 15s just in case
- delay: 15s
#Lower the desk
- platform: gpio
pin:
number: GPIO22
inverted: true
interlock: raise_desk
on_turn_on:
- delay: 15s
Logs so far - Cant’t get uart logs
[15:03:52][V][mdns:117]: Services:
[15:03:52][V][mdns:119]: - _esphomelib, _tcp, 6053
[15:03:52][V][mdns:121]: TXT: friendly_name = Standing Desk
[15:03:52][V][mdns:121]: TXT: version = 2024.4.2
[15:03:52][V][mdns:121]: TXT: mac = 409151ab9734
[15:03:52][V][mdns:121]: TXT: platform = ESP32
[15:03:52][V][mdns:121]: TXT: board = esp32dev
[15:03:52][V][mdns:121]: TXT: api_encryption = Noise_NNpsk0_25519_ChaChaPoly_SHA256
[15:03:52][VV][scheduler:226]: Running interval 'update' with interval=60000 last_execution=768395 (now=828396)
[15:03:54][VV][scheduler:226]: Running interval '' with interval=60000 last_execution=772092 (now=832092)
[15:03:54][VV][scheduler:226]: Running interval 'update' with interval=60000 last_execution=772340 (now=832345)
[15:03:55][VV][api.service:602]: on_ping_request: PingRequest {}
[15:03:55][VV][api.service:043]: send_ping_response: PingResponse {}
[15:04:26][VV][api.service:690]: on_switch_command_request: SwitchCommandRequest {
key: 529781321
state: YES
[15:04:26][D][switch:012]: 'Raise Desk' Turning ON.
[15:04:26][D][switch:055]: 'Raise Desk': Sending state ON
[15:04:27][VV][scheduler:032]: set_timeout(name='', timeout=15000)
[15:04:27][VV][api.service:156]: send_switch_state_response: SwitchStateResponse {
key: 529781321
state: YES
[15:04:27][VV][api.service:690]: on_switch_command_request: SwitchCommandRequest {
key: 529781321
state: NO
[15:04:27][D][switch:016]: 'Raise Desk' Turning OFF.
[15:04:27][D][switch:055]: 'Raise Desk': Sending state OFF
key: 529781321
state: NO
[15:04:31][VV][api.service:690]: on_switch_command_request: SwitchCommandRequest {
key: 2153922382
state: YES
[15:04:31][D][switch:012]: 'Request Desk Height' Turning ON.
[15:04:31][D][switch:055]: 'Request Desk Height': Sending state ON
[15:04:31][VV][scheduler:032]: set_timeout(name='', timeout=100)
[15:04:31][VV][api.service:156]: send_switch_state_response: SwitchStateResponse {
key: 2153922382
state: YES
[15:04:31][VV][scheduler:226]: Running timeout '' with interval=100 last_execution=869049 (now=869154)
[15:04:31][D][switch:016]: 'Request Desk Height' Turning OFF.
[15:04:31][D][switch:055]: 'Request Desk Height': Sending state OFF
key: 2153922382
state: NO
[15:04:37][VV][scheduler:226]: Running interval 'update' with interval=60000 last_execution=814817 (now=874818)
[15:04:38][VV][scheduler:226]: Running interval 'update' with interval=60000 last_execution=816082 (now=876090)
[15:04:41][VV][scheduler:226]: Running timeout '' with interval=15000 last_execution=864543 (now=879544)
[15:04:41][D][switch:016]: 'Raise Desk' Turning OFF.
HA Details
Up and down is working.
One last thing i noticed:
The desk usually is showing the height in inch not cm or mm when the display is working.
I also opend my controller board and checked my RJ45 layout. It matched the config from #Option 1
UPDATE:
I had to solder the TX pin of the controller to GPIO17 instead of GPIO3. No I’m getting the uart logs. I still facing the same issue as @jcastro. When looking at my logs the 5th and the 6th byte caltulate my desk height. Therefore i still cant see the height in HA. I managed to switch from inch to cm in the controllers settings.
@Mahko_Mahko @ssieb do you have any further tips how to get the height to work?
LOGS:
[20:43:51][D][switch:012]: 'Request Desk Height' Turning ON.
[20:43:51][D][switch:055]: 'Request Desk Height': Sending state ON
[20:43:51][VV][scheduler:032]: set_timeout(name='', timeout=100)
[20:43:51][VV][api.service:156]: send_switch_state_response: SwitchStateResponse {
key: 2153922382
state: YES
[20:43:51][D][uart_debug:176]: <<< 242,242,1,3,2,232,15,253,126
[20:43:51][VV][scheduler:226]: Running timeout '' with interval=100 last_execution=12504 (now=12610)
[20:43:51][D][switch:016]: 'Request Desk Height' Turning OFF.
[20:43:51][D][switch:055]: 'Request Desk Height': Sending state OFF
key: 2153922382
state: NO
[20:43:52][D][uart_debug:176]: <<< 242,242,1,3,2,232,15,253,126
[20:43:53][D][uart_debug:176]: <<< 242,242,1,3,2,232,15,253,126
[20:43:54][D][uart_debug:176]: <<< 242,242,1,3,2,232,15,253,126
CONFIG:
uart:
- id: desk_uart
baud_rate: 9600
rx_pin: GPIO17
debug:
after:
bytes: 9
