Can you measure 5V on the relevant power wires with a multimeter?
Which desk do you have?
You could also try another Esp, especially if it was a cheap clone.
Also triple check all of your connections and solder where possible.
I dont have a multimeter, the only boards i have are the cheap d1 mini clones - i see you mentioned moving to diguno i have 2 of those but not sure of the wiring
desk is an uplift v2 from 2021
Hey getting some errors updating to ESPHome 2023.12.0 about pins being used multiple times, so cannot update.
Some breaking change introduced since pre 2012.12?
Itâs a new validation. You shouldnât be doing that.
ah, ok i have no idea what its referring to, though. The GUI is reffereing to four different places where gpio is red underlined and its referring to pin 4 and pin 5, twice.
these 2:
output:
- platform: gpio
pin: ${desky_up_pin}
inverted: true
- platform: gpio
pin: ${desky_down_pin}
inverted: true
and
#Raise the desk
- platform: gpio
pin:
number: D2
# mode: INPUT_PULLUP
inverted: true
interlock: lower_desk
on_turn_on:
#Auto off after 15s just in case
- delay: 15s
- switch.turn_off: raise_desk
#Lower the desk
- platform: gpio
pin:
number: D1
inverted: true
interlock: raise_desk
on_turn_on:
esphome:
friendly_name: BDI Standing Desk
on_boot:
priority: -100.0
then:
#Request a desk height update after boot.
- delay: 5s
- switch.turn_on: wake_desk_and_get_height
substitutions:
#Use your own ESP pin values
desky_request_height_pin: GPIO14 #Request desk height | white wire
desky_purple_pin: GPIO13 #purple wire
desky_down_pin: GPIO05 #Move desk down | yellow wire
desky_up_pin: GPIO04 #Move desk up | green wire
output:
- platform: gpio
inverted: true
- platform: gpio
inverted: true
- platform: gpio
pin: ${desky_purple_pin}
inverted: true
esp8266:
board: d1_mini
early_pin_init: False
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "[REDACT]"
ota:
password: "[REDACT]"
## For Memory Sensor (debug platform in sensor)
debug:
update_interval: 30s
# Sensors
- platform: uptime
- platform: wifi_signal
name: "Desky WiFi Signal"
update_interval: 60s
- platform: debug
free:
fragmentation:
name: "Heap Fragmentation"
block:
name: "Heap Max Block"
loop_time:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bdi-Standing-Desk"
password: "vdJyTtjMWGrb"
captive_portal:
##Notes/Info
## Home Assistant Thread: https://community.home-assistant.io/t/desky-standing-desk/383790/3
## ssieb who generously donated his time and knowledge to developing the custom component may offer some support on the Discord thread (please read both threads first).
## https://discord.com/channels/429907082951524364/952464939480645642
#Notes:
# 1. Use this component at own risk. It has not had extensive testing. May void warranty or cause desk faults etc.
# 2. This controller may bypass desk safety features like collision detection.
# 3. This component doesn't know about the values stored in your desk. Values in this config are (and must be) set independently.
# 4. ssieb's solution may be a lot simpler and cleaner for most people. I've cobbled together some more features in this config because I can't programn in C++.
#Troubleshooting Tips:
#If you ever get a flashing ASr message, you might need to reset your desk.
#https://desky.com.au/blogs/news/reset-standing-desk-control-panel#:~:text=When%20ready%2C%20press%20and%20hold,Hooray!
#TODO
#Ask ssieb to make change requests (move logic to component code)
# Invert pins
# Get Desk Height On Boot
# Interlock Up/Down Pins (If not done already)
# Interrupt/stop movement function (Stop desk motion)
#other
# Test collision detection
# Limit external component fetch to just desky?
# Fix Desk Is moving on Boot.
external_components:
#Fetch ssieb's custom component# https://github.com/ssieb/custom_components/tree/master/components/desky
- source:
type: git
url: https://github.com/ssieb/custom_components
components: [ desky ]
uart:
- id: desk_uart
baud_rate: 9600
rx_pin: 1 #Labelled TX on my D1mini clone (mislabelled?)
##You can uncomment the debug section below to see UART messages.
# debug:
# direction: RX
# dummy_receiver: true
# after:
# bytes: 4
# sequence:
# - lambda: UARTDebug::log_int(direction, bytes, ',');
desky:
##Uncomment this block to use Ssieb's move_to componet function.
# up:
# number: 4 #D2
# inverted: true
# down:
# number: 5 #D1
# inverted: true
# stopping_distance: 15 # optional distance from target to turn off moving, default 15
height: # Sensor publishing the current height
accuracy_decimals: 1
unit_of_measurement: cm
#any other sensor options
filters:
- delta: 0.05 #Only send values to HA if they change
- throttle: 200ms #Limit values sent to Ha to 5 per sec.
- multiply: 0.1 #convert from mm to cm
on_value:
then:
#If the value changes, then the desk is moving
- binary_sensor.template.publish:
state: ON
- delay: 300ms
#Assume it's stopped moving if no height changes after a short time.
state: Off
binary_sensor:
name: "Desky Is Moving"
filters:
- delayed_off: 400ms
#If the desk isn't moving for a bit we better turn off attempts at movement. It's like poor man's collision detection?
on_release:
then:
- button.press: desky_stop_desk
button:
#Stop movement
on_press:
then:
- switch.turn_off: lower_desk
# Combination Buttons
name: Desky Button 1
on_press:
then:
- output.turn_on: up_green_wire
- output.turn_on: down_yellow_wire
- delay: 300ms
- output.turn_off: down_yellow_wire
- output.turn_off: up_green_wire
- platform: output
output: purple_wire
name: Desky Button 2
duration: 300ms
name: Desky Button 3
on_press:
then:
- output.turn_on: purple_wire
- delay: 300ms
- output.turn_off: purple_wire
name: Desky Button 4
on_press:
then:
- delay: 300ms
#Move to function
name: Go To Desky Height x
on_press:
then:
##Option 1: Uncomment to use Ssieb's move_to componet functions
# - lambda: id(my_desky).move_to(id(desky_target_height).state*10);
##Option 2: Uncomment to use Mahko's lambda alternative
#Check if we need to move desk up or down from current position
if:
condition:
#Current height is more than target height, then move desk down
lambda: |-
return id(desky_target_height).state < id(desky_height).state;
then:
- switch.turn_on: lower_desk
- wait_until:
#Run until the difference between current and target state is < stopping distance
condition:
lambda: return abs((id(desky_height).state - (id(desky_target_height).state)))<(id(stopping_distance_cm).state);
else:
#Current height is less than target height, move desk up
- switch.turn_on: raise_desk
- wait_until:
condition:
#Run until the difference between current and target state is <0.3cm
number:
#Target Height ("Move desk to height x").
#You should probably limit the range you can move the desk to to within the limits you've set via the control panel, perhaps offset a little within the range.
#Sending commands higher/lower than this may cause error messages and require desk reset (or worse).
name: "Desky Target Height"
optimistic: true
min_value: 65.0
max_value: 122.0
step: 0.1
#Offset correction - Adjust until you get the best accuracy.
#The desk keeps moving for a little while after the up/down pins are released and we try to account for this.
#1.5cm was about right on mine
name: "Desky Stopping Distance cm"
optimistic: true
min_value: 0
max_value: 2
step: 0.1
restore_value: true
initial_value: 1.5
#Define some preset heights.
#You can freely define as many adjustable presets as you like.
#These are all seperate/independant of what you've set via the control panel (we can't retrieve them currently).
#Standing Height #1 - Set a standing height.
name: "Standing Height 1"
optimistic: true
#Limit the range
min_value: 110
max_value: 120
step: 0.1
restore_value: true
initial_value: 115
name: "Standing Height 2"
optimistic: true
#Limit the range
min_value: 115
max_value: 125
step: 0.1
restore_value: true
initial_value: 120
#Sitting Height #1 - Set a sitting height. This is independant of what you've set via the control panel.
name: "Sitting Height 1"
optimistic: true
#Limit the range
min_value: 65
max_value: 69
step: 0.1
restore_value: true
initial_value: 67.0
#Sitting Height #2 - Set a sitting height. This is independant of what you've set via the control panel.
name: "Sitting Height 2"
optimistic: true
#Limit the range
min_value: 72.6
max_value: 82.6
step: 0.1
restore_value: true
initial_value: 77.6
switch:
#wake up ther desk and request it sends its height
- platform: gpio
name: "Request Desk Height"
pin:
number: D5
inverted: true
on_turn_on:
- delay: 100ms
- switch.turn_off: wake_desk_and_get_height
- platform: restart
#Raise the desk
- platform: gpio
pin:
number: D2
inverted: true
on_turn_on:
- delay: 15s
#Lower the desk
- platform: gpio
pin:
number: D1
inverted: true
on_turn_on:
- delay: 15s
D1 and D2 are the same as GPIO5 and GPIO4. You have the pins defined as outputs and also as switches. Use one or the other.
ahh. not sure I can do that easily ![]()
maybe code might have to rewritten.
what if I just added allow_other_uses: true to the 2 offending pins?
EDIT: the above wonât fix the output of the pins. OK, not easy fix for me.
I think my example config used pins twice.
Quite possibly it was bad practice I implemented.
Probably a hacky solution to have the custom component, some up/down switches, and the presets all working in parallel from memory.
Likely needs review. Best solution may be to address at the custom component level (feature request to merge up/down switches and memory presets into custom component)
I can take a look at this at some point but itâs unlikely to be for a few weeks.
Edit: You could (but possibly not should) bypass it with allow_other_uses:
Edit 2: I see youâve tried that. Possibly it needs to be added to 3 places, including the custom component pin definition?
thanks! it was suggested that I remove the output section and change the output to switches, which I did in this version but it still gives those validation errors on pins 4 and 5 error on lines 343, 356, 369 and 373, but pin D2 == GPIO4 may also be reused.:
Hereâs my moodified.yaml
esphome:
on_boot:
priority: -100.0
then:
- delay: 5s
substitutions:
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
key: "REDACTED"
ota:
password: "REDACTED"
debug:
# Sensors
- platform: uptime
- platform: debug
free:
fragmentation:
block:
loop_time:
wifi:
ap:
captive_portal:
##Notes/Info
#Notes:
#TODO
# Invert pins
#other
- source:
type: git
uart:
- id: desk_uart
baud_rate: 9600
# debug:
# direction: RX
# after:
# bytes: 4
# sequence:
desky:
# up:
# number: 4 #D2
# inverted: true
# down:
# number: 5 #D1
# inverted: true
filters:
on_value:
then:
state: ON
- delay: 300ms
state: Off
binary_sensor:
filters:
on_release:
then:
button:
#Stop movement
on_press:
then:
on_press:
then:
- switch.turn_on: up_green_wire
- switch.turn_on: down_yellow_wire
- delay: 300ms
- switch.turn_off: down_yellow_wire
- switch.turn_off: up_green_wire
on_press:
then:
- switch.turn_on: purple_wire
- delay: 300ms
- switch.turn_off: purple_wire
on_press:
then:
- delay: 300ms
on_press:
then:
- delay: 300ms
#Move to function
on_press:
then:
if:
condition:
lambda: |-
then:
- wait_until:
condition:
else:
- wait_until:
condition:
number:
optimistic: true
min_value: 65.0
max_value: 122.0
step: 0.1
optimistic: true
min_value: 0
max_value: 2
step: 0.1
restore_value: true
initial_value: 1.5
optimistic: true
#Limit the range
min_value: 110
max_value: 120
step: 0.1
restore_value: true
initial_value: 115
optimistic: true
#Limit the range
min_value: 115
max_value: 125
step: 0.1
restore_value: true
initial_value: 120
optimistic: true
#Limit the range
min_value: 65
max_value: 69
step: 0.1
restore_value: true
initial_value: 67.0
optimistic: true
#Limit the range
min_value: 72.6
max_value: 82.6
step: 0.1
restore_value: true
initial_value: 77.6
switch:
- platform: gpio
pin:
number: D5
inverted: true
on_turn_on:
- delay: 100ms
- platform: restart
#Raise the desk
- platform: gpio
pin:
number: D2
inverted: true
on_turn_on:
- delay: 15s
#Lower the desk
- platform: gpio
pin:
number: D1
inverted: true
on_turn_on:
- delay: 15s
- platform: gpio
inverted: true
- platform: gpio
inverted: true
- platform: gpio
inverted: true
D1 is GPIO5 and D2 is GPIO4.
So id: up_green_wire is basically a duplicate of id: raise_desk and down_yellow_wire of id: lower_desk. The switches duplicate functionality and cause the conflict.
This was bad design on my part when implementing the memory preset feature.
So some refactoring is required through the config to just define the up/down switch once and repoint things to use it throughout.
Just on mobile on hols so canât help much with specifics ATM.
thanks @Mahko_Mahko ! I was able to get some more help from others, especially @firstof9 and members in the ESPHome Discord to fix it. This yaml seems to retain all functionality and obey all the pin re-use rules.
I kept getting into a loop of fixing one thing, and getting another issue so I couldnât really excute the fix myself.
Have a look below, if you wish. Cheers
esphome:
on_boot:
priority: -100.0
then:
- delay: 5s
substitutions:
# Use pin lables like god intended
#desky_request_height_pin: D5 #Request desk height | white wire
desky_purple_pin: D7 #purple wire
#desky_down_pin: D1 #Move desk down | yellow wire
#desky_up_pin: D2 #Move desk up | green wire
esp8266:
board: d1_mini
# Enable logging
logger:
api:
encryption:
key: "[REDACTED]"
ota:
password: "[REDACTED]"
debug:
# Sensors
- platform: uptime
- platform: debug
free:
fragmentation:
block:
loop_time:
wifi:
ap:
captive_portal:
##Notes/Info
#Notes:
#TODO
# Invert pins
#other
- source:
type: git
uart:
- id: desk_uart
baud_rate: 9600
# debug:
# direction: RX
# after:
# bytes: 4
# sequence:
desky:
# up:
# number: 4 #D2
# inverted: true
# down:
# number: 5 #D1
# inverted: true
filters:
on_value:
then:
state: ON
- delay: 300ms
state: Off
binary_sensor:
filters:
on_release:
then:
button:
#Stop movement
on_press:
then:
on_press:
then:
- delay: 300ms
on_press:
then:
- delay: 300ms
on_press:
then:
- delay: 300ms
on_press:
then:
- delay: 300ms
#Move to function
on_press:
then:
if:
condition:
lambda: |-
then:
- wait_until:
condition:
else:
- wait_until:
condition:
number:
optimistic: true
min_value: 65.0
max_value: 122.0
step: 0.1
optimistic: true
min_value: 0
max_value: 2
step: 0.1
restore_value: true
initial_value: 1.5
optimistic: true
#Limit the range
min_value: 110
max_value: 120
step: 0.1
restore_value: true
initial_value: 115
optimistic: true
#Limit the range
min_value: 115
max_value: 125
step: 0.1
restore_value: true
initial_value: 120
optimistic: true
#Limit the range
min_value: 65
max_value: 69
step: 0.1
restore_value: true
initial_value: 67.0
optimistic: true
#Limit the range
min_value: 72.6
max_value: 82.6
step: 0.1
restore_value: true
initial_value: 77.6
switch:
- platform: gpio
pin:
number: D5
inverted: true
on_turn_on:
- delay: 100ms
- platform: restart
#Raise the desk
- platform: gpio
pin:
number: D2
inverted: true
on_turn_on:
- delay: 15s
#Lower the desk
- platform: gpio
pin:
number: D1
inverted: true
on_turn_on:
- delay: 15s
- platform: gpio
inverted: true
Hopefully it can help others. ![]()
Does this still work with new desky controller?
What is the model number?
I agree that is the belief, but I personally disagree with it. Our company needed to know which of these would be up to some serious use, so I loaded two of each brand of desk with 200 lbs. and ran them up and down day and night for weeks. Both Linak desks died in less than 5000 cycles and the Jiecang desks were still going after 40,000 cycles when I stopped the test.
The Linak desks have smoother and quieter motion, but seem to have problems with durability (at least the ones I had).
Interesting. What duty cycle did you use for testing?
In the interest of time, we ran one of each brand at 20% duty cycle, even though they are rated for 10%, hoping for quick success. When the Linak desk failed so quickly, we started a second one at 5% duty to rule out things like overheating. That one ran longer, but not much. (I misspoke previously; it got to around 6000 cycles that time.)
The failure was a brake that acts while descending, presumably to prevent the motor from acting as a generator and overloading the electronics. It started making a horrible squealing sound.
So i built one of these a little over a year ago, and I noticed that my monitor has to be adjusted to be at eyeline height when i change the desk from sit to stand and viceversa. It seemed dumb to have the desk automated, and having to adjsut the monitor by handâŚso⌠i made this:
i have limit switches for both positions, and i have a HA scene that moves both desk and monitor at the same time. I used this video as a guide to figure out the electronics/mechanics:
Was it overkill and ridiculous? yeah, it was⌠but it was a fun build.
Oh wow. Next level.
However the theory goes that you shouldnât need to do that. Your sit and stand positions should both result in right angle arms which means the relative height of the monitor should be the same.
So could possibly be an issue with either your presets or your desk range.
I did a crazy hand cranked desk project during lockdown which ultimately failed because of insufficient range lol.
I did one of those Drzzz projects too⌠They are great!
