For version 2.0 I ditched the cam (Not high enough resolution for my use case) and learnt to 3d design/3d print.
Now ‘Cranky’ looks pretty good I reckon.
Edit: 2023-05-31.
Long Term Reliability: Still going strong!
Parts Lists:
- D1 mini or similar (I’d probably go for an ESP32 these days)
- L298N (for version 2 I went with a L298N mini rather than a full sized L298N, and powered the whole thing via 5v usb rather than a 12V wall wart). This makes it slower but simpler and more compact.
- A bh1750. Consider getting one with a nice dome for athletics. Mines just poking through a hole in the top right there.
- End Stop Limit Switch. Consider getting a slightly larger one and think about how/where you’ll mount this.
- Momentary button to toggle state. Mine is mounted on the far side that you can’t see in this photo. See config. If open, then close, if closed then open, if moving then stop, if stopped move in opposite direction to last.
- A suitable coupler.
- A motor (I’m driving my 12V motor with 5V, It takes about 3min to open!)
- You could think about adding a rain drop sensor. Or building one separately. Close the windows when it rains!
Config:
Expand Me
substitutions:
devicename: shed_window_crank
friendly_name: Shed Cranky
device_description: Shed Cranky
esphome:
comment: ${device_description}
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
# Enable logging
logger:
# level: VERY_VERBOSE
# Enable Home Assistant API
api:
ota:
# deep_sleep:
# run_duration: 24h
# sleep_duration: 1s
text_sensor:
# Reports the ESPHome Version with compile date
- platform: version
name: ${friendly_name} ESPHome Version
#Tracks last movement direction to help with the one-touch sit/stand toggle button.
# # Light Sensor - Needs i2c and the data/clock pins
i2c:
sda: 4
#D1 Data D2/GPIO4 > Green > BH1750 SDA
scl: 5
#D1 Clock D1/GPIO5 > blue > BH1750 SCL
scan: True
- platform: bh1750
name: "Illuminance Shed Window"
address: 0x23
update_interval: 60s
filters:
- median:
window_size: 3
send_every: 3
# Motor Control
#Set up control, Define Pins
#GPIO15 = D8 >>> IN3
#GPIO13 = D7 >>> IN4
output:
- platform: gpio
pin: D8
- platform: gpio
pin: D7
#USe the pins above in two switches.
switch:
- platform: output
output: 'win_close_shed'
internal: false
- platform: output
output: 'win_open'
internal: false
#Use the switches to define a cover.
cover:
# optimistic: true
device_class: window
lambda: |-
if (id(shed_win_state).state) {
return COVER_CLOSED;
} else {
return COVER_OPEN;
# if (id(shed_win_state).state) {
# return COVER_CLOSED;
# } else {
# return COVER_OPEN;
open_action:
#Don't open if open
then:
if:
binary_sensor.is_on: shed_win_state
then:
- switch.turn_off: winclose_shed
- switch.turn_on: winopen_shed
- delay: 165s
- switch.turn_off: winopen_shed
else:
close_action:
#Don't close if closed
then:
if:
binary_sensor.is_off: shed_win_state
then:
- switch.turn_on: winclose_shed
- delay: 170s
else:
#for stop button
stop_action:
# End Stop
binary_sensor:
- platform: status
name: "Shed Window ESP32 Status"
#D5 > yellow > C
#Ground > black > NO
- platform: gpio
# device_class: window
internal: false
pin:
number: D6
#try activating pullup...
mode: INPUT_PULLUP
#D3 problematic. Try D5
name: "shed window end stop"
on_press:
then:
filters:
- invert:
# # Button Placeholder
# // window is opening
# // window is open and not moving
# // window is closing
# // win is closed and not moving
- platform: gpio
#D4 (yellow) to whatever
pin: D4
name: "toggle shed window"
internal: true
filters:
invert:
on_press:
then:
- lambda: |
if (id(tr_win_open_shed).position == COVER_OPEN) {
if (id(winopen_shed).state){
id(tr_win_open_shed).stop();
} else {
id(tr_win_open_shed).close();
} else {
if (id(winclose_shed).state){
} else {
id(tr_win_open_shed).open();
# - lambda: |
# if (id(tr_win_open_shed).current_operation == CoverOperation::COVER_OPERATION_IDLE) {
# // Cover is not opening or closing, toggle it. https://esphome.io/components/cover/index.html#cover-stop-action
# auto call = id(tr_win_open_shed).make_call();
# call.set_command_toggle();
# call.perform();
# } else {
# // Cover is opening or closing, stop it.
# call.set_command_stop();
# call.perform();
Enclosure:
https://www.printables.com/model/494747-cranky-window-opener-enclosure/files
Edit: 2023-10-28 added details to clarify features.
