Pass through wiring seems fine, desk controls all work fine when the control panel is run through the breakout and the ESP32 is fully disconnected.
Had some success using the config you suggested with GPIO21 set for uart, after rigging that up I see uart debug messages in the log. Iāve included those below, it doesnāt appear to be very consistent but then I donāt really know what Iām looking at.
Holding the down button:
[17:38:17][D][uart_debug:176]: <<< 255
[17:38:18][D][uart_debug:176]: <<< 255
[17:38:19][D][uart_debug:176]: <<< 255
[17:38:20][D][uart_debug:176]: <<< 255
[17:42:02][D][uart_debug:176]: <<< 255,255,255,255
[17:42:02][D][uart_debug:176]: <<< 127,255,255,255
[17:42:03][D][uart_debug:176]: <<< 255,255
[17:42:03][D][uart_debug:176]: <<< 253,255
[17:42:04][D][uart_debug:176]: <<< 255
[17:42:04][D][uart_debug:176]: <<< 253
[17:42:04][D][uart_debug:176]: <<< 109
[17:42:05][D][uart_debug:176]: <<< 255
[17:42:06][D][uart_debug:176]: <<< 255
Holding up button:
[17:39:10][D][uart_debug:176]: <<< 255
[17:39:11][D][uart_debug:176]: <<< 219,255,251,251
[17:39:11][D][uart_debug:176]: <<< 255,255,255,255
[17:39:11][D][uart_debug:176]: <<< 251
[17:39:12][D][uart_debug:176]: <<< 255,255,255,255
[17:39:13][D][uart_debug:176]: <<< 255,255,255,223
[17:39:13][D][uart_debug:176]: <<< 219,223,255,255
[17:39:13][D][uart_debug:176]: <<< 223,251,251,251
[17:39:13][D][uart_debug:176]: <<< 251,219,255,251
[17:39:13][D][uart_debug:176]: <<< 251,251,251,219
[17:39:13][D][uart_debug:176]: <<< 255,251,255,255
[17:39:13][D][uart_debug:176]: <<< 255,255,251,255
[17:39:13][D][uart_debug:176]: <<< 219,255,255,255
[17:39:13][D][uart_debug:176]: <<< 255,219,251,255
[17:39:13][D][uart_debug:176]: <<< 255,251,251,255
[17:39:13][D][uart_debug:176]: <<< 251,251,223,255
[17:39:13][D][uart_debug:176]: <<< 255,255,223,223
[17:39:14][D][uart_debug:176]: <<< 255,255,223,255
[17:39:14][D][uart_debug:176]: <<< 255,255,255,255
[17:39:14][D][uart_debug:176]: <<< 251,255,255,255
[17:39:14][D][uart_debug:176]: <<< 251,251,251,255
[17:39:14][D][uart_debug:176]: <<< 219,251,251,219
[17:39:14][D][uart_debug:176]: <<< 219,251,219,251
[17:39:14][D][uart_debug:176]: <<< 251,251,219,251
[17:39:14][D][uart_debug:176]: <<< 255,251,251,251
[17:39:14][D][uart_debug:176]: <<< 251,251,251,219
[17:39:14][D][uart_debug:176]: <<< 251,219,219,251
[17:39:14][D][uart_debug:176]: <<< 219,251,251,251
[17:39:15][D][uart_debug:176]: <<< 251,255,255,251
[17:39:15][D][uart_debug:176]: <<< 251,251,251,251
[17:39:15][D][uart_debug:176]: <<< 255,251,219,255
[17:39:15][D][uart_debug:176]: <<< 255,251,251,251
I then tried using GPIO21 for the rx_pin in your more complex config and found an interesting result:
- if the
up or down pins are connected the ESP32 stops sending logs to the console and stops responding to network traffic
- if the
request desk height pin is connected the ESP32 maintains network connectivity and the logs show a constant stream of the following:
[17:47:36][D][uart_debug:176]: <<< 0,192,0,224
[17:47:36][D][uart_debug:176]: <<< 224,254,224,192
[17:47:36][D][uart_debug:176]: <<< 224,192,224,224
[17:47:36][D][uart_debug:176]: <<< 192,224,224,224
[17:47:36][D][uart_debug:176]: <<< 62,254,248,248
[17:47:36][D][uart_debug:176]: <<< 248,224,192,192
[17:47:36][D][uart_debug:176]: <<< 192,192,254,248
[17:47:36][D][uart_debug:176]: <<< 192,240,240,192
[17:47:36][D][uart_debug:176]: <<< 192,192,240,254
[17:47:36][D][uart_debug:176]: <<< 254,248,240,240
[17:47:36][D][uart_debug:176]: <<< 192,248,192,240
[17:47:36][D][uart_debug:176]: <<< 240,192,240,254
[17:47:36][D][uart_debug:176]: <<< 248,248,192,240
[17:47:36][W][component:237]: Component uart took a long time for an operation (193 ms).
[17:47:36][W][component:238]: Components should block for at most 30 ms.
[17:47:36][D][uart_debug:176]: <<< 240,0,0,224
[17:47:36][D][uart_debug:176]: <<< 0,192,0,192
[17:47:36][D][uart_debug:176]: <<< 0,224,0,192
[17:47:36][D][uart_debug:176]: <<< 0,240,0,240
[17:47:37][D][uart_debug:176]: <<< 224,62,254,248
[17:47:37][D][uart_debug:176]: <<< 224,192,224,224
[17:47:37][W][component:237]: Component uart took a long time for an operation (177 ms).
[17:47:37][W][component:238]: Components should block for at most 30 ms.
[17:47:37][D][uart_debug:176]: <<< 224,192,192,224
[17:47:37][D][uart_debug:176]: <<< 254,248,224,248
[17:47:37][D][uart_debug:176]: <<< 224,248,192,224
[17:47:37][D][uart_debug:176]: <<< 224,192,0,192
[17:47:37][D][uart_debug:176]: <<< 0,224,0,192
[17:47:37][D][uart_debug:176]: <<< 0,192,0,224
[17:47:37][D][uart_debug:176]: <<< 0,192,0,240
[17:47:37][D][uart_debug:176]: <<< 0,192,254,254
[17:47:37][D][uart_debug:176]: <<< 248,224,192,224
[17:47:37][D][uart_debug:176]: <<< 192,192,224,192
[17:47:37][D][uart_debug:176]: <<< 192,192,0,224
[17:47:37][W][component:237]: Component uart took a long time for an operation (181 ms).
[17:47:37][D][uart_debug:176]: <<< 0,192,0,192
[17:47:37][D][uart_debug:176]: <<< 0,224,0,224
[17:47:37][D][uart_debug:176]: <<< 0,192,254,248
[17:47:37][D][uart_debug:176]: <<< 224,192,240,192
[17:47:37][D][uart_debug:176]: <<< 240,240,192,192
[17:47:37][D][uart_debug:176]: <<< 62,254,254,248
[17:47:37][D][uart_debug:176]: <<< 240,240,192,240
[17:47:37][D][uart_debug:176]: <<< 192,192,192,192
[17:47:37][D][uart_debug:176]: <<< 240,192,192,62
[17:47:37][D][uart_debug:176]: <<< 254,248,240,240
[17:47:37][W][component:237]: Component uart took a long time for an operation (169 ms).
[17:47:37][D][uart_debug:176]: <<< 248,224,224,224
[17:47:37][D][uart_debug:176]: <<< 224,192,224,192
[17:47:37][D][uart_debug:176]: <<< 224,224,254,248
[17:47:37][D][uart_debug:176]: <<< 248,248,224,192
[17:47:37][D][uart_debug:176]: <<< 224,224,192,192
[17:47:37][D][uart_debug:176]: <<< 192,192,192,0
[17:47:37][D][uart_debug:176]: <<< 224,0,192,0
[17:47:37][D][uart_debug:176]: <<< 192,0,192,0
[17:47:37][W][component:237]: Component uart took a long time for an operation (183 ms).
[17:47:37][D][uart_debug:176]: <<< 254,248,248,248
[17:47:37][D][uart_debug:176]: <<< 192,240,192,192
[17:47:37][D][uart_debug:176]: <<< 192,254,0,240
[17:47:37][D][uart_debug:176]: <<< 0,240,0,240
[17:47:37][D][uart_debug:176]: <<< 0,240,0,192
[17:47:37][D][uart_debug:176]: <<< 0,192,248,248
[17:47:37][D][uart_debug:176]: <<< 192,62,254,254
[17:47:37][D][uart_debug:176]: <<< 224,192,192,0
[17:47:37][D][uart_debug:176]: <<< 240,62,254,240
[17:47:38][D][uart_debug:176]: <<< 248,240,240,192
[17:47:38][W][component:237]: Component uart took a long time for an operation (181 ms).
[17:47:38][W][component:238]: Components should block for at most 30 ms.
[17:47:38][D][uart_debug:176]: <<< 240,240,240,240
[17:47:38][D][uart_debug:176]: <<< 192,240,254,192
[17:47:38][D][uart_debug:176]: <<< 224,224,224,192
[17:47:38][D][uart_debug:176]: <<< 192,0,192,0
[17:47:38][D][uart_debug:176]: <<< 224,0,224,248
[17:47:38][D][uart_debug:176]: <<< 248,248,192,224
[17:47:38][D][uart_debug:176]: <<< 224,240,192,192
[17:47:38][D][uart_debug:176]: <<< 62,254,254,248
[17:47:38][D][uart_debug:176]: <<< 240,240,192,240
[17:47:38][D][uart_debug:176]: <<< 192,240,192,192
[17:47:38][W][component:237]: Component uart took a long time for an operation (175 ms).
[17:47:38][D][uart_debug:176]: <<< 240,254,248,254
[17:47:38][D][uart_debug:176]: <<< 248,240,248,192
[17:47:38][D][uart_debug:176]: <<< 240,240,192,0
[17:47:38][D][uart_debug:176]: <<< 192,62,254,248
[17:47:38][D][uart_debug:176]: <<< 224,192,224,192
[17:47:38][D][uart_debug:176]: <<< 224,192,192,192
[17:47:38][D][uart_debug:176]: <<< 62,248,248,224
[17:47:38][D][uart_debug:176]: <<< 248,224,230,192
[17:47:38][W][component:237]: Component uart took a long time for an operation (110 ms).
