I have a new (true) Deta 2 way switch (96951HA) from bunnings with WB3S chip.
I’ve flashed using Libretuya ESPHome branch.
My Yaml works perfectly as a single switch going to load.
It also works perfectly physically in 2 way mode, with a physical (non smart switch) at the remote end.
The issue I have is, if I turn it off using the remote switch, it doesn’t register that it is turned off locally (in esphome or home assistant).
The device has 2 relays in it, for 2 way switching. It looks like it is physically wired so if one relay is switched it automatically toggles the other relay.
EDIT
I don’t know what pin (if any) is connected to remote relay to allow notification that it has been switched at the remote end.
Looks like “P8” reports status - on or off (inverted)
P9 controls remote switch
# P24 - status led
# P14 - relay
# P26 - Local button
# P9 - Remote button
# P8 - power status (inverted)
A physical inspection of chip look like the only soldered connections are:
PIN:
1 -VCCRXFE
3 - EN (26) - Button1
4 - P14 - Relay
8 - VCC
9 - Gnd
10 - Txdata2 - P7
11 - Rxdata2
12 - PWM3
13 - PWM2 - P8 (P24) - Status LED
15 - RXD1
My Yaml:
substitutions:
device_name: masterbedbedsw
friendly_name: "masterbedbedsw"
device_ip: 192.168.1.128
esphome:
friendly_name: ${friendly_name}
libretuya:
board: wb3s
framework:
version: dev
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "E1piLrGNTl63LcmF5jIyKN3qLljwxGjbPqKOwNDgKR8="
ota:
password: "2c0bd0708c739debd734dc13d2d6fc42"
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: ${device_ip}
gateway: 192.168.1.1
subnet: 255.255.255.0
# Enable fallback hotspot in case wifi connection fails
ap:
ssid: "Masterbed-bed-Sw"
password: "pxYBUfA4yRII"
# The web_server & sensor components can be removed without affecting core functionaility.
web_server:
port: 80
- platform: wifi_signal
name: ${device_name} Wifi Signal Strength
update_interval: 60s
- platform: uptime
button:
- platform: factory_reset
name: Restart with Factory Default Settings
output:
# status led
- platform: gpio
pin: P24
inverted: true
#Relay
- platform: gpio
pin: P14
light:
# status Led
- platform: binary
name: "${friendly_name} status_led"
output: white_status_led
# Top (or only) button
- platform: binary
output: relay_output
# Buttons
binary_sensor:
- platform: gpio
pin:
number: P26
mode: INPUT
inverted: True
name: "${friendly_name} Top Button"
filters:
- delayed_off: 50ms
#toggle relay on push
on_press:
- light.toggle: light1
- platform: gpio
pin:
number: P9
mode: INPUT
inverted: True
name: "${friendly_name} remote Button"
filters:
- delayed_off: 50ms
on_press:
- platform: gpio
# https://esphome.io/components/binary_sensor/gpio.html
pin:
number: P8
inverted: True
switch:
- platform: restart
# present the state of the switch in HA based on the sensor
# https://esphome.io/components/switch/template.html
lambda: |-
if (id(powersensor).state) {
return true;
} else {
return false;
# https://esphome.io/guides/automations.html#if-action
turn_on_action:
- if:
condition:
binary_sensor.is_off: powersensor
then:
turn_off_action:
- if:
condition:
binary_sensor.is_on: powersensor
then:
