I have some deta sg and dg wall switches that are flashed with tasmota. Is there a way to control the led of the switch (not link led) without triggering the relay? I want to be able to have the relay engaged (to power a smart ceiling fan), but not have the blue Led show all night as it creates too much light in the room at night. I also have it set to turn the relay off with long press and toggle the smart bulb on short press.
I suspect that the led is wired to the relay enablement so it may not be able to seperate the two, just wanted to find out someone has been successful in resolving this?
