On the ESPHome’s Web Server Component documentation it is stated the following about accessing the ESP node via mDNS:
“To navigate to the web server in your browser, either use the IP address of the node or use <node_name>.local/ (note the trailing forward slash) via mDNS.”
Using mDNS to resolve the “.local” address is feasible with Windows and Apple OS, but when trying to resolve this URL with Android OS with Edge or Chrome browsers, it issues a “DNS_PROBE_FINISHED_NXDOMAIN” error message as mDNS is not supported.
This is an open issue/ limitation on Android platform that has been going on since 2014 and is detailed in the links below. To access the node in this case, only with the node’s IP address.
Since 2019: Sign in - Google Accounts
Since 2014: 405925 - chromium - An open-source project to help move the web forward. - Monorail
The request is to highlight the Android limitation on the ESPHome’s Web Server Component documentation and that only IP addresses can be used with Android OS + Chrome / Edge browsers
Documentation URL:
