Hello i need your help. I have a variable with the actual tv channel. example: activeChannel = ard.
Now i want to check a channel change. example activeChannel=zdf
I need a trigger (changeChannel) for a automation.
Any idea?
Thanx Oliver
Any idea?
Thanx Oliver
Is that the state of an entity, or the attribute of an entity?
it ist a state of an entity. i generate it with a template from an attribute.
Please format your YAML correctly, as explained in the big blue box at the top.
Then it’s a normal automation with a state based trigger:
platform: state
entity_id: sensor.solo4k_aktiver_sender
to: 'zdf'
Sorry, my question was not clear enough. I want to trigger every channel change. From ard to zdf, from zdf to ard, from wdr to ndr etc.
In that case, drop the to: line, then it will trigger on every state change of sensor.solo4k_aktiver_sender.
Thank you very much. Its functional!
