I recently moved to an old laptop for my HA instance and am pretty happy with it. Everything is quicker and having a built in keyboard and mouse is nice. Another benefit is if there are power issues I don’t have to worry about corruption on the Pi.
That got me thinking that the laptop knows when its on battery or on the AC adapter, why not make a sensor and notification.
- platform: command_line
command: "cat /sys/class/power_supply/AC/online"
sensors:
power_status:
entity_id: sensor.power
value_template: "{%- if is_state('sensor.power', '1') -%} OK {%- else -%} Power Outage {%- endif %}"
Tested it and it works well. Plugged in the sensor reports ‘OK’ and when I pull the plug it reports ‘Power Outage’.
Question is can these somehow be combined? The command line sensor component has a value_template option but I don’t know how to pull the value from the sensor and have it output like the template sensor.
I am also planning to pull the battery life value to determine if I should stop the HA instance if the power is out for an extended period. I just need to do some more poking around the /sys/class folder to find the right file.
scan_interval: 1
value_template: '{% if value is equalto "1" %} OK {% else %} Power Outage {% endif %}'
Considering all options at the moment. If I had a spare SSD I’d already be in testing mode. I don’t really understand the differences between them all so I think for me personally I need to be able to search these forums for answers to basic linux questions and it helps to know a few people are successfully running the same OS. Obviously using the RPi with AIO has been fantastic for the support side of things here and getting started with linux.
I was thinking server for the virtual machine and ability to make snapshot backups as mentioned here.
Nice! With a Virtual machine it’s easy to test, and a small foot print so you can easily go back/forth.
I am currently using VMware Workstation (a top of Windows 10) but you can use the free VMware ESXi providing it has the support of the hardware you are running it on. Network drivers are usually the tricky one.
Ubuntu server is pretty light and I run my HASS instance with 1 vCPU and 512Mb RAM. I can help with any other questions you have!
I swapped over to Ubuntu server. I added the Desktop gui as I like being able to pull up a website and copy commands or copy example code. Still pretty lightweight. Install went smooth.
Edit: so server is a bit more of a PTA for certain things, like connecting to a wireless network. add your drivers, restart, manual config of the connection ect. Ill see if I keep running into stuff like this, not worth the headache when mint or ubuntu desktop is still pretty light and pretty plug and play.
Thanks for the update. I’ll just have to try it - intel celeron NUC so hopefully drivers wont be too painful.
Once you have these things working it should be fine though, not like you have to do it all again every time you update.
A disk image once everything is up and working would be just fine for a disaster backup so server isn’t that important to me and I’m planning on just running tests for a month or two anyway. Ubuntu desktop might be a better starting point for me.
Yes, you can probably query the battery charge percentage into a sensor or state in a similar way. This is my sensors.yml file (I’m using a Lenovo X200 laptop, your device’s paths and numeric values may differ)
name: Laptop PSU Connected
scan_interval: 1
value_template: '{% if value is equalto "1" %} Connected {% else %} Disconnected {% endif %}'
name: Laptop CPU Temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: "{{ value | multiply(0.001) | round(1) }}"
name: Laptop Battery Percent
command: "cat /sys/class/power_supply/BAT0/capacity"
unit_of_measurement: "%"
value_template: "{{ value }}"
You should be able to then simply include the battery charge in the trigger template
automations.yml (generated through the web interface via “Configuration”, “Automations”, hence the long id)
- id: '1623708680935'
alias: Laptop Power Notification
description: ''
- platform: state
entity_id: sensor.laptop_psu_connected
condition: []
- service: notify.mobile_app_phone
message: 'Laptop PSU state changed to {{ states.sensor.laptop_psu_connected.state
}}, Battery {{ states.sensor.laptop_battery_percent.state }} %'
mode: single
