I have several MQTT (through Zigbee2MQTT) electricity sockets around the house which default to ‘off’ state after a power cut. I’d like to be able to detect when a power cut has happened and switch these devices back on again.
Would the best way to do that be to have an automation detect when one of these devices which should always be on (e.g. the fridge/freezer) has been in an “off” state for more than a certain amount of time and switch them all back on?
Or a better question to ask is if they should always be on when there is power then why have them on a smart/controllable outlet in the first place? Just plug them into a hardwired outlet.
I have two refrigerators and a deep freezer that I monitor. One of the refrigerators doesn’t have a freezer and I don’t monitor the freezer section of my main refrigerator. I figure if the fridge is cold then so is the freezer. The only thing that won’t guard against is if someone leaves the freezer door open. But we would likely notice that in time.
The batteries report a low value (27% for the freezer and 34% for the refrigerators) all the time but they stay like that for a long time then fall off rapidly when they do finally die.
It’s an old house, there aren’t enough sockets to go around and putting a power monitor plug on one would make the fridge stick out too much unfortunately! The same goes for most of the other devices on the smart sockets.
Also, the sockets were cheaper than the power monitoring plugs
