I have e Zigbee bulb that is behind a lightswitch. I had the idea for an automation: when I switch off the light, the state change to “unavailable” would trigger an automation to turn off some other bulbs, that are not behind a lightswitch.
However, it turns out that state change actually happens long after I switch off the light. Is there a way to make ZHA detect this faster?
No. By definition, when a zigbee device lose power, it cannot report anything.
The only setting here, is the time before ZHA consider a device unavailable
Would be cool that some manufacturer include a big enough capacitor so that a “last will” message could be sent, though, if that makes sense electrically.
Thanks, that’s very helpful! I understand a device cannot send a message once power is cut off. (Although your capacitor/last will idea is really cool!) But I figured the way a device is marked unavailable should be based on some timeout. Glad that you pointed me right to that. I’ve changed mine from 7200 to 5 seconds. Let’s see how that works out.
I had a similar scenario as yours.
I’ve set it to 60 seconds, and so far so good, as long as I accept the delay of up to a minute.
My use case was similar. Next to my bed I have an electrical switch to turn off one light in my bedroom, but I have a second one, which is only managed from a switch next to the door. So I would set up an automation so that when HA detects as unavailble the ‘bed light’, the ‘door light’ would turn off.
Mind that sometimes (it has gotten better) detecting turning on might have some delay as well, depending on how complete you want your use-case.
I use uptime kuma to monitor zigbee devices avability using mqtt payload. If a device is offline ha sends me a message on my telegram account.
I use this for a quit some time and this is working flavesly.
It monitors mqtt avability topic. If devices is unavailable for 60 seconds it sends message. For some I had to put longer period to avoid false reports.
That’s probably useful for you, but this is about reducing the time before the device becomes unavailable
You’re just adding 60 seconds to that period through kuma…
Well this works for me as I want it to work. Whenever I check this device is really offline. Sometimes it does send me report that device is offline but it isn’t. That’s why for some I extended this period.
What I found out while monitoring this is that even battery powered devices can became available on its own. Didn’t know that.
Usually light switches became unavailable and then available probably due rerouting.
This is question for me?
There isnt much to it. Just set up mqtt monitor settings, fill in username password and use topic accordingly ie. zigbee2mqtt/Android TV led strip/availability.
And set up notification as you wish. I set up notification using telegram. And that is it.
Active devices (routers or mains powered end devices): by default they have to check-in every 10 minutes. If they don’t, they will be pinged, if that fails the device will be marked as offline.
Passive devices (everything that is not an active device, mostly battery powered devices): these devices need to check-in every 25 hours, they cannot be pinged so if they don’t they will be marked as offline.
So, I just moved from Hue to Zigbee2MQTT, using the HA Connect ZBT-1. Unfortunately - as I am living in a rented flat - I have to use the power on / off state of the main bulbs in my rooms to determine the usage state of the room (other bulbs, music, heating is turned on or off depending on the state of the main bulb).
Now, while I found out that I can improve how quickly the on state of a bulb is noticed by adjusting the reporting interval of a bulb, this can obviously not be used to detect the power off state (as, when there is no power, the bulb cannot send status updates).
The best I found is to adjust the timeout of the general availability setting in the Z2M settings to 1. Unfortunately this is minutes and does not seem to work reliably. I sometimes have to wait way longer than 1 minute for HA to recognize that a bulb has been turned off. 5 minutes and more are no exception despite the setting to 1 minute. And even a reliable 1 minute would stretch the acceptable time to the max…
With Hue this worked much faster and much more reliable. After searching the internet and interviewing several AIs, there seems to be no way to improve the situation. Now, I really don’t want to go back to Hue, but the current situation is not acceptable. So, I am asking you as my last hope before taking the effort to go back to Hue: Is there anything I can do? Can I regularly ping devices from within HA? Would flashing from ezsp to ember help? Is there anything on the roadmap that will improve the situation anytime soon?
You can use uptime kuma to monitor any zigbee device if it is using mqtt. If your devices are configured with ie z2m then you can use uptime kuma to monitor availability topic for devices and report back ie. using telegram if device is detected as offline.
