Hello everybody, first time poster here…
i just bought a couple of Shelly Qubino Wave Shutter modules (Z-Wave) to control roller shutters. What i want to do is setting a % of opening with a long press on the wall switch (short press-> blinds go down, 1 long press-> blind closes at 50%.
The problem is that i can’t find a way to check if the Shelly module receives a command from the wall switch…
Can anybody help out a beginner?
Thanks in advance.
M
Hi, did you find a solution? I want also to “read out” the manual button use and use it as a trigger for automation. Th shelly support send me the info, that i can perhaps read out the “command class switch multilevel” commands but i do not know how this will work…
