Detecting NaN sensor (DS18b20) lambda/else
Trying to detect when a DS18b20 goes offline or NaN and then execute a LED based on the state
I have referred to this post: https://community.home-assistant.io/t/sensor-nan-value-as-trigger/480230/4?u=domain_int butI really need to add an else in the statement and dont know how to do it
I tried doing this:
      then:
        - if:
            condition:
              lambda: (id(temp_probe_error).state)) == "NaN";
            then:
              - light.turn_on: sensor_check
          else:
            - light.turn_off: sensor_check
tried this
       - lambda:
          if (isnan(id(temp_probe_error).state)) {id(sensor_check).turn_off();} else {id(sensor_check).turn_on();}
and I tried this
  - platform: dallas_temp
    update_interval: 10s
    on_value:
      then:
        - lambda:
            } else {
I am a newb when it comes to lambdas but am not afraid to search
The main issue is to do with the else statement
Hope someone can help
any help???
I tried this too:
    update_interval: 1s
    filters:
      - skip_initial: 5
      - clamp:
          min_value: 2
          max_value: 90
          ignore_out_of_range: true
      - median:
          window_size: 7
          send_every: 4
          send_first_at: 3
      - lambda: |-
          if (isnan(x)) {
            return -997;
        } else {
            return x;
Bevor
dallas_temp
You have one wire and get the ID from the sensor?
Errrrr… would there be something more constructive to contribute behind such an inane reply instead of clocking up your reply count?
    lambda: |-
      int volts = 120;
      if (!(isnan(id(voltage).state))) {
        volts = id(voltage).state;
      return (id(current0).state * volts);
Instead of else, set a base variable.
