My Mom is increasingly forgetting to turn off the faucet in her bathroom sink and we wake up before her in the morning to discover it has been running for who knows how many hours.
Is there a sensor I can purchase which will work with HA to send a notification if the water has been running for more than a set period?
I don’t want to have to DIY the hardware if possible.
You don’t mention where your mom lives, but in the United States Flume (flumewater.com) sells a device that is fairly easy to install and works well. It will notify you of high usage directly without HA but also has an integration. In some cases the purchase will be credited by your local water utility.
I have a none-specific solution: a water pulse meter on my main entry and a esp/wemos.
This does not measure an individual use of course, but it can detect a longer use of ‘water’, which can be shower, washing machine, etc.
With some 'logic you could tweak this to: if usage more than (say) 10m > alert
Of course you can install a simiilar solution for the particular faucet but effort/cost <> gain (your decision)
2 additional Docker containers are required @unmesh59 - rtl_sdr (decrypts radio stream and streams it to a port) and metermon (reads rtl_sdr port and sends mqtt). I run these 2 containers on HA docker instance (HA complains about this in health status but having other containers never caused any issues for me in several years of running it).
