Could you please suggest some ways to use HA to help in detecting watering issues?
I have a flow rate sensor in front of pipes around my garden and I’d like to be alerted in case of any broken pipe, etc.
I see some scenarios but I’m not good enough in automation yet. If you point me into the right direction that help me a lot.
For instance, a simple alert to Telegram on huge water consumption at unexpected time.
I mean If a tap has broken or a fitting has come off on a pipe the flow rate will be much higher than during standard watering (hose).
At the same time, lawn watering also consumes a lot. So I need to have a calendar when high volume consumption is OK.
I can send message to Telegram (on hass start, for example). But I have no idea on how to create automation reading the file to take this schedule into account…
Well, at this moment I’ve created a simple sensor returning number of seconds since last flow update.
I use it to hide some charts (visibility) in 10 minutes after watering stops.
sensors:
caisson_time_since_water_pulses_change:
friendly_name: "Time Since Caisson Water Pulses Change"
value_template: >
{% set last_changed = states.sensor.caisson_water_pulses.last_changed %}
{% set now = now() %}
{% set time_diff = now - last_changed %}
{{ time_diff.total_seconds() | int }}
unit_of_measurement: "seconds"
icon_template: "mdi:clock-outline"
But how to alert when watering starts and continues with approximately the same flow rate for 5 minutes (but not immediately and not alert again and again)?
Any ideas highly appreciated.!
