working away at my bushfire automation and have hit another speed bump.
I want to determine a risk level based on the direction of an incident from home (bearing 1) and the wind direction (bearing 2).
In effect, I am looking for a method to compare two directional bearing values to check if they are similar. they are both compass bearings so in a range of 0-360 degrees. Say one is 8 degrees, and another is 355 degrees. Or one is 192 degrees and the other is 199 degrees.
Very similar (e.g. 8 degrees and 10 degrees) = Highest risk (or the 8deg and 355deg spanner in the works!)
Quite similar (e.g. 8 degrees and 25 degrees) = High risk
Somewhat similar (e.g. 8 degrees and 85 degrees) = Moderate risk,
Not similar = (e.g. 8 degrees and 193 degrees) = Low risk.
Or compare compass directions, which I also have to hand (like NNE and NE = High risk. NNE and SE = low risk).
Has anyone happened to write a template that compares values in such a way that they have handy?
{% set x = (states('sensor.incident_1_bearing') | float(0) -
states('sensor.openweathermap_wind_bearing') | float(0)) | abs %}
{{ { 0.0 <= x <= 22.4: Extreme
22.5 <= x <= 44.8: Higher
44.9 <= x <= 67.2: High
67.3 <= x <= 89.6: Mod
89.7 <= x <= 112.0: Mid
112.1 <= x <= 134.4: Low
134.5 <= x <= 156.8: Lowest
156.9 <= x <= 179.2: None
179.3 <= x <= 201.6: Lowest
201.7 <= x <= 224.0: Low
224.1 <= x <= 246.4: Mid
246.5 <= x <= 268.8: Mod
268.9 <= x <= 291.2: High
291.3 <= x <= 313.6: Higher
313.7 <= x <= 360.0: Extreme }.get(true, 'unknown') }}
Note
You can also reduce the number of keys in the dictionary by combining the keys that have the same values.
{{ { 0.0 <= x <= 22.4 or 313.7 <= x <= 360.0: Extreme
22.5 <= x <= 44.8 or 291.3 <= x <= 313.6: Higher
44.9 <= x <= 67.2 or 268.9 <= x <= 291.2: High
67.3 <= x <= 89.6 or 246.5 <= x <= 268.8: Mod
89.7 <= x <= 112.0 or 224.1 <= x <= 246.4: Mid
112.1 <= x <= 134.4 or 201.7 <= x <= 224.0: Low
134.5 <= x <= 156.8 or 179.3 <= x <= 201.6: Lowest
156.9 <= x <= 179.2: None }.get(true, 'unknown') }}
