So the usual: I am new at home assistant and therefore do not have too much experience with yaml file configuration.
I am trying to setup the “Deutsche Bahn” integration with several connections. Therefore I would like to have several train connections which I then can integrate into my frontend.
If I add only one connection via the following code, everything works fine:
It states that it is removed because of webscraping? I dont understand, are not all of these plugins like weather or other train timetable based on such techniques or what is the difference? And why is this frowned upon? Will there be a replacement?
