Dev/bus/usb”: no such file or directory "
I am going through this Google Coral USB + Frigate + PROXMOX - #74 by DDAVE
I am trying to compile the stack inside portainer with this code:
#######################FRIGATE
version: '1.0'
services:
  frigate:
   container_name: frigate
   image: blakeblackshear/frigate:stable-amd64
   restart: always
   devices:
    - /dev/bus/usb:/dev/bus/usb
   volumes:
    - /etc/localtime:/etc/localtime
    - /home/frigate/config.yml:/config/config.yml:ro
   ports:
    - 5000:5000
    - 1935:1935
   environment:
    FRIGATE RTSP PASSWORD: "--------"
but after some minutes it return a veeeery long error that ends like this "ror response from daemon: error gathering device information while adding custom device “/dev/bus/usb”: no such file or directory ".
Please, anyone has a solution?
First off, recommend setting image as image: blakeblackshear/frigate:stable so you’re running the latest version of frigate. Then check your passed volumes.
