I have a NUC with Z-Stick Gen 5 plugged.
It was working fine but then I updated linux (apt update upgrade…) and HA (with GUI) and now the zwave is not working.
I have a linux + virtualbox with Home assistant os.
I started to “debug” on linux :
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0658:0200 Sigma Designs, Inc. Aeotec Z-Stick Gen5 (ZW090) - UZB
Bus 001 Device 003: ID 8087:0aaa Intel Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg
[ 749.883555] usb 1-1: USB disconnect, device number 5
[ 756.205873] usb 1-2: new full-speed USB device number 6 using xhci_hcd
[ 756.355551] usb 1-2: New USB device found, idVendor=0658, idProduct=0200, bcdDevice= 0.00
[ 756.355554] usb 1-2: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 756.357011] cdc_acm 1-2:1.0: ttyACM0: USB ACM device
[ 756.737999] usb 1-2: reset full-speed USB device number 6 using xhci_hcd
[ 757.170558] usb 1-2: reset full-speed USB device number 6 using xhci_hcd
So for me the USB is well plug and linux detect it but it is not available in /dev/ttyACM0 as before and as describe in dmesg
ls /dev/tty*
/dev/tty /dev/tty14 /dev/tty20 /dev/tty27 /dev/tty33 /dev/tty4 /dev/tty46 /dev/tty52 /dev/tty59 /dev/tty8 /dev/ttyS13 /dev/ttyS2 /dev/ttyS26 /dev/ttyS4
/dev/tty0 /dev/tty15 /dev/tty21 /dev/tty28 /dev/tty34 /dev/tty40 /dev/tty47 /dev/tty53 /dev/tty6 /dev/tty9 /dev/ttyS14 /dev/ttyS20 /dev/ttyS27 /dev/ttyS5
/dev/tty1 /dev/tty16 /dev/tty22 /dev/tty29 /dev/tty35 /dev/tty41 /dev/tty48 /dev/tty54 /dev/tty60 /dev/ttyS0 /dev/ttyS15 /dev/ttyS21 /dev/ttyS28 /dev/ttyS6
/dev/tty10 /dev/tty17 /dev/tty23 /dev/tty3 /dev/tty36 /dev/tty42 /dev/tty49 /dev/tty55 /dev/tty61 /dev/ttyS1 /dev/ttyS16 /dev/ttyS22 /dev/ttyS29 /dev/ttyS7
/dev/tty11 /dev/tty18 /dev/tty24 /dev/tty30 /dev/tty37 /dev/tty43 /dev/tty5 /dev/tty56 /dev/tty62 /dev/ttyS10 /dev/ttyS17 /dev/ttyS23 /dev/ttyS3 /dev/ttyS8
/dev/tty12 /dev/tty19 /dev/tty25 /dev/tty31 /dev/tty38 /dev/tty44 /dev/tty50 /dev/tty57 /dev/tty63 /dev/ttyS11 /dev/ttyS18 /dev/ttyS24 /dev/ttyS30 /dev/ttyS9
/dev/tty13 /dev/tty2 /dev/tty26 /dev/tty32 /dev/tty39 /dev/tty45 /dev/tty51 /dev/tty58 /dev/tty7 /dev/ttyS12 /dev/ttyS19 /dev/ttyS25 /dev/ttyS31 /dev/ttyprintk
If I unplug the stick, plug it again I do not see any differences in /dev/tty* without and with the stick.
Any ideas ?
