Develop Statistics Configuration via Template?
Still heavily learning-by-doing, i want to use Statistics Sensor for my Power Meter, to detect unsual Power drain. Statistics Sensors seem to be the right Tool.
As i have no clue about right charateristics, timespan, i want to avoid to restart HA Hundered of Times and spam the History Stats.
(How) can i use:
  - platform: statistics
    name: "Bathroom humidity mean over last 24 hours"
    entity_id: sensor.bathroom_humidity
    state_characteristic: mean
    max_age:
      hours: 24
in /developer-tools/template/, to instantly see the Result, without always edit configuration.yaml and Restart?
I’m not sure what you mean by this:
Just add the sensor to an entities card so you can see the state any time you want.
Sorry for beeing not clear :crazy_face:
I mean: To find out the proper settings for that statistics sensor, i want to play around with its Settings. E.g. start with a Timespan like 10 Minutes and see what happens, then observe the Result for 20 Minutes. Then see what is the Difference between “mean” and “average_linear”. Have a look, what the Output of “noisiness” is, and if it might be helpful.
Ah I see.
You’re stuck with the restart dance unfortunately.
Templates only have access to the current state. So there’s no easy way to calculate a mean of previous states.
Too bad. Thanks anyway for your fast responses, appreciate it! As my first attempts with the statistics are totally unsatisfying i might start another hands-on Thread… :wink:
