i’ve been watching bruh automation channel and i’ve noticed that he has many services on his home assistant:
one of them is also a useful restart.
why dont I have these services? or i can add them anyhow?
Ben may be using a dev branch.
so this is not standard version? I miss that i can’t restart HA from this UI, only from putty.
I think there’s a restart button that displays if you turn on config: as well.
Is your install up to date?
yes, installed it yesterday. fresh from the website.
can you please explain this ?
It shows as failed when it DOES work because the webUI gets disconnected from the back-end, try force refreshing the page in the browser right after calling the service, you should see that HASS is down.
You’re right, i’ve tried. thank you!
Put a top-level config: entry in your YAML and you’ll get a config panel in the UI. It has a “restart server” button.
