Developer: What is the proper way to name MQTT devices now?
Hey! I am maintaining a service which exposes Unraid OS servers state as mqtt entities for home assistant.
The service exposes each servers:
  • Virtual machine entities (turn on/off)
  • Docker container buttons (turn on, off, restart)
  • Server control buttons (power, array on, etc)
This works properly, a single container can manage multiple Unraid servers. Which is where the problem starts. Until now I would use the Server name as unique_id and device.name.
Considering that each server can expose the same container or VM. Now with the latest update I am not sure how I can make it work for multiple servers. Since I would need to set the unique name the server name to be able to differentiate the mqtt devices between two different servers. As of the latest update I get this error:
MQTT device name is equal to entity name in your config
This is how it is setup:
      JSON.stringify({
        payload_on: "started",
        payload_off: "stopped",
        value_template: "{{ value_json.status }}",
        state_topic: `${env.MQTTBaseTopic}/${serverTitleSanitised}/${docker.name}`,
        json_attributes_topic: `${env.MQTTBaseTopic}/${serverTitleSanitised}/${docker.name}`,
        unique_id: `${serverTitleSanitised}_${docker.name}`,
        device: {
          identifiers: [serverTitleSanitised],
          manufacturer: server.serverDetails.motherboard,
          model: "Docker"
        command_topic: `${env.MQTTBaseTopic}/${serverTitleSanitised}/${docker.name}/dockerState`
      { retain: env.RetainMessages }
My question is, how can I setup properly the names so it works for multiple servers and does not bother home assistant
Speculation is on:
What i understand is that, you need to supply different names for device and sensors and sensor names are generated on the fly with concetenation.
Device: bedroom multi sensor
Entities;
  • illuminance
  • Temperature
Speculation is off.
I don’t know :slight_smile:
Expansive thread on this. The first post also has links about all of this.
There is this post: The naming of MQTT entities changes to correspond with HA guidelines | Home Assistant Developer Docs
What I understood is that the name of the sensor must not have the device name in it.
Before:
Device name: XXX
Sensor name: XXX_YYY
Now:
Device name: XXX
Sensor name: YYY
So regarding your example, maybe remove “serverTitleSanitised” from “name:”
