Developing Custom Component but all sensors are inside single entity
So I am working on getting Flair Smart Vents added into my HA. I have found some older add on with Github but have required modification. I am new to Python and to HA so not sure the best way to do this. I have it working but not creating the entities correct.
This is the code I am using to create the entities.
def setup_platform(hass, config, add_entities, discovery_info=None):
    """Setup the sensor platform"""
    name = config.get(CONF_NAME)
    client_id = config.get(CONF_CLIENT_ID)
    client_secret = config.get(CONF_CLIENT_SECRET)
    home_id = config.get(CONF_HOME_ID)
    monitored_conditions = config.get(CONF_MONITORED_CONDITIONS)
    sensors = []
    if monitored_conditions is not None:
        for item in monitored_conditions:
            sensors += [FlairVent(
                    name, client_id, client_secret, home_id, _MONITORED_CONDITIONS[item])]
    add_entities(sensors, True)
    return
This is how it is displaying.
What I am hoping for is a way to loop through what you see here for each vent and make a separate entity for each of those. Any help or assistance would be greatly appreciated.
