Developing Home Assistant Core in a VSCode Devcontainer
Setting Up the Local Repository
- Ensure that
gitinstalled on your development wokstation - Visit the Home Assistant Core repository and click Fork.
- Open a terminal and set up your local repository
git clone https://github.com/YOUR_GIT_USERNAME/core.git Home Assistant-core
cd Home Assistant-core
git remote add upstream https://github.com/home-assistant/core.git
- Create a new feature branch that tracks the
devbranch in
git checkout -b my_dev_branch --track origin/dev
- Open the local repository in VSCode
Configuring Home Assistant
By default, the devcontainer will create the config directory inside the container if it doesn't already exist. Optionally, you can override this by bind mounting a config directory from your local filesystem, which can be helpful for long-term persistence or swapping in/out different configurations to support development.
To do this, include a list of mounts inside /.devcontainer/devcontainer.json:
"mounts": [
// Custom configuration directory
"source=${localEnv:HOME}/path/to/config,target=${containerWorkspaceFolder}/config,type=bind",
If these mounts are modified, then the DevContainer must to be rebuilt
- Press
F1, and enterRemote-Containers: Rebuild Container
See Advanced container configuration for more information.
Running Home Assistant
If this the first time running Home Assistant, or the container has been rebuilt, you should use this method for starting Home Assistant. This method will install all of the out-of-the-box libraries required to run HA (including the debugger, which can then be used later).
Open the the local repository in VSCode
Accept the prompt to "Reopen in Container"
Start HA in the container via the menu options:
Terminal | Run Task... | Run Home Assistant Core -
Open HA in a web browser at http://localhost:8123
See Debugging Home Assistant for more information about debug mode.
Keeping Code Up To Date
_This is adapted from https://developers.home-assistant.io/docs/development_catching_up_
The following commands will keep your local feature branch up-to-date with Home Assistant's official dev branch.
Reminder: upstream is the official HA repository, origin is your remote repository that was forked from it
- Switch to a local feature branch
- Pull the latest commits from a HA's
upstream/devbranch - Replay the upstream commits to the local branch, then re-applies local changes
- Push the combined commits back to the forked repository on GitHub
git checkout my_dev_branch
git fetch upstream dev
git rebase upstream/dev
git push origin --force
Set Up Home Assistant's Remote Python Debugger
Add the following to /config/configuration.yaml:
debugpy:
start: true
wait: false
See Remote Python Debugger - Home Assistant for more information.
Start Debugging
Using the debugger after using the Running Home Assistant startup method is not preferred for debugging, as it the debugger does not attach at the very beginning of the Home Assistant startup process. To start Home Assistant immediately in debug mode, do the following.
- Stop any running tasks if you used the Running Home Assistant method
Terminal | Terminate Task... | Run Home Assistant Core - Switch to the VSCode Run & Debug view
- Select the
Home Assistantlaunch configuration from the dropdown - Start the debugger
If You Use Run Task to Start Home Assistant
- Ensure that the HA devcontainer is running (`Terminal | Run Task... | Run Home Assistant Core``)
- Select the
Home Assistant: Attach Locallaunch configuration from the dropdown - Start the debugger
Debugging Custom Components and Libraries
When developing custom components or libraries that exist in other local respoitories on your development machine, the easiest way to incorporate these into Home Assistant is to bind mount those repositories into HA's config directory.
To do this, include a list of mounts inside /.devcontainer/devcontainer.json, similar to this example:
"mounts": [
// Custom component
"source=${localEnv:HOME}/path/to/custom_repo/custom_components/component_name,target=${containerWorkspaceFolder}/config/custom_components/component_name,type=bind",
//Custom library
//"source=${localEnv:HOME}/path/to/custom_repo/custom_libraries/library_name,target=${containerWorkspaceFolder}/config/custom_libraries/library_name,type=bind",
Add more bind mounts as needed for your use case.
If these mounts are modified, then the devcontainer must to be rebuilt
- Press
Custom Components
Custom components are mounted in the container under config/custom_components, which is a Home Assistant standard.
Custom Libraries
Custom libraries are mounted under config/custom_libraries. Note that custom_libraries is a personal naming preference, and is not prescribed in the Home Assistant docs.
In order to develop a custom library, HA needs to be started with the --skip-pip argument as described here: Building a Python library for an API | Home Assistant Developer Docs
This launch config option is available in the Run & Debug view as Home Assistant (skip pip)
Prerequisites
Before starting HA in skip pip mode, start HA at least once in normal mode, which will install all out-of the-box libraries the via the normal HA boot process. This can be done via either of these methods:
- Running Home Assistant
- Debugging Home Assistant
Overriding an Out-Of-The-Box Library
If overriding a out-of-the-box-in library, it must first be removed from the DevContainer. Go to the VSCode terminal and enter the following:
pip uninstall library_name
Installing a Custom Library
To then enable a custom library, have pip install it from the filesystem. It should be accessible via the bind mount(s) created above. Go to the VSCode terminal and enter the following:
pip install -e ./config/custom_libraries/library_name
Using the Custom Library
Stop the running instance of Home Assistant, then restart using the Home Assistant (skip pip) debug option shown above
Seems debugging only works via debugpy. Without it the default debug config doesn’t work for me.
