I have an Everspring ST812 moisture sensor that doesn’t come in with a device type (so just on/off).
I can set the device_class: moisture in the Dev Tools for the binary sensor and for awhile it reflects correctly. Correct icon and wet/dry.
After an unknown period of time or an unknown action it’s back to not having a device_class.
When I first paired it the other day I did set up a mdi:water icon and I am removing that when setting the device_class. I’ve noticed that when it reverts, that icon is back.
Is setting the state in Dev Tools not a persistent change?
Thanks. I didn’t feel good about it since it is after all called “Developer Tools” but I wasn’t fully comprehending this page until you confirmed it. I see now that Configuration Variables = configuration file.
Continuing with this, what would be the recommended structure for a change like this if I want to keep it out of configuration.yaml?
Put it in a binary-sensors.yaml file?
You wouldn’t have a sample snippet, would you? Not quite to the point where I am able to make them from scratch and get the formatting correct.
