Hey everybody! I am hoping you guys can help me out!
I recently purchased a Wyze Outdoor Switch and promptly flashed ESPHome onto it by following the instructions here. It worked great for a few days, until it suddenly stopped working, without me doing anything to it. It shows active in the ESPHome Addon, but would be ‘Unavailable’ in HA.
I reflashed the device multiple times, and it would work for about a minute, and then stop responding again. My wifi network shows the device is connected, but it will not ping. HA also automatically discovers it when I plug it in, but when I go to the Integrations tab to set it up, I get this message: Can't connect to ESP. Please make sure your YAML file contains an 'api:' line.
but the API is in the YAML file.
I have attached the YAML config here
substitutions:
display_name: ESPHome Outdoor Switch 1
# Higher value gives lower watt readout
current_res: "0.001"
# Lower value gives lower voltage readout
voltage_div: "770"
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: !secret wifi_ssid
fast_connect: true
power_save_mode: none
manual_ip:
static_ip: !secret outdoor_switch_1_ip
gateway: !secret network_gateway
subnet: !secret network_subnet
dns1: !secret network_dns
ap:
ssid: ${display_name} AP
password: !secret ap_password
captive_portal:
logger:
api:
ota:
web_server:
switch:
- platform: gpio
name: ${display_name} Relay 1
pin:
number: GPIO15
inverted: false
on_turn_on:
- light.turn_on: relay1_led
on_turn_off:
- light.turn_off: relay1_led
- platform: gpio
name: ${display_name} Relay 2
pin:
number: GPIO32
inverted: false
on_turn_on:
- light.turn_on: relay2_led
on_turn_off:
- light.turn_off: relay2_led
- platform: restart
output:
- platform: gpio
pin: GPIO19
inverted: True
- platform: gpio
pin: GPIO16
inverted: True
light:
- platform: binary
name: "Relay 1 LED"
internal: true
output: relay1_led_gpio
- platform: binary
name: "Relay 2 LED"
internal: true
output: relay2_led_gpio
- platform: adc
pin: GPIO34
update_interval: 10s
attenuation: 11db
- platform: hlw8012
sel_pin:
number: GPIO25
inverted: true
cf_pin: GPIO27
cf1_pin: GPIO26
current_resistor: ${current_res}
voltage_divider: ${voltage_div}
change_mode_every: 3
update_interval: 3s
current:
unit_of_measurement: A
accuracy_decimals: 2
voltage:
unit_of_measurement: V
accuracy_decimals: 1
power:
unit_of_measurement: W
accuracy_decimals: 0
filters:
- calibrate_linear:
- 0.0 -> 0.0
- 134 -> 58
binary_sensor:
- platform: gpio
internal: true
pin:
number: GPIO18
mode: INPUT_PULLDOWN
inverted: True
name: ${display_name} Button 1
on_press:
- switch.toggle: relay1
- platform: gpio
internal: true
pin:
number: GPIO17
inverted: True
name: ${display_name} Button 2
on_press:
- switch.toggle: relay2
status_led:
pin:
number: GPIO5
inverted: true
I cant get any logs from the ESPHome Config for the device, as it cannot connect.
