I have Aqara door sensor that connected to my homeassistant via Sonoff Zigbee 3.0 dongle. In homeassistant there is one device for aqara sensor and 4 entities of that device. So I’m using @matt8707 's dashboard design and i want to add temperature and battery percentage readings to this button. But i couldn’t manage to add one button for all states of entities. If it was one entity and the attributes it was so easy to setup that way.
I added some screenshots so you can understand what i mean. Below you can see right bottom corner i have a door sensor. The second screenshot, you can see my entities for one device. This is my example template script. for my door sensors.
person:
template:
- base
- circle
state_display: >
if (entity) {
return variables.state === 'home'
? variables.translate_home
: variables.state === 'not_home'
? variables.translate_not_home
: variables.state;
return variables.translate_unknown;
triggers_update: sensor.time
tap_action:
action: none
styles:
grid:
- grid-template-areas: |
"icon icon circle circle"
"n n n n"
"s s s weight"
- grid-template-columns: repeat(4, 1fr)
- grid-template-rows: auto repeat(2, min-content)
- gap: 1.3%
- align-items: start
- will-change: transform
custom_fields:
icon:
- clip-path: circle()
- width: 82%
- pointer-events: none
- display: grid
weight:
- justify-self: end
custom_fields:
icon: >
return entity && variables.entity_picture
? `<img src="${variables.entity_picture}" width="100%">`
: null;
weight: |
return `<span>${states[variables.entity_weight].state}</span>`
