Hello
I have a working automation that uses an event trigger to listen for zha_events on a specific device_id.
zha_event
device_id
I want to turn it into a blueprint to make it reusable for different devices, however I can not make the trigger works with templates
But when I try in the developer tools, the template gives the right value: screenshot
I am doing something wrong?
I think the cause of your issue is that Event triggers only support Limited templates and device_id() is likely not part of that… You can move the template to a Template condition, where a wider range of template functions are allowed.
device_id()
trigger: - platform: event event_type: zha_event condition: - "{{ trigger.event.data.device_id == device_id('switch.example')}}" action: ....
Works perfectly, thanks you!
