I have zigbee2mqtt installed. MQTT integration via UI. Auto-discovery should be true (by default). I have lots of xiaomi sensors of all type integrated with no problem.
Today I bought this new GU10 light from Lidl and paired with no problems with z2m. I can control the light perfectly. It appears as manufacturer TuYa and model TS0502A in z2m
My problem is that the device does not appears in HA. I reset everything multiple times. Pair and repair de bulb again. Even reinstalled MQTT integration in HA. However, the light does not appear.
How can I make it appear in Home Assistant? Even in the MQTT integration, if I subscribe to the topic, I can listen when the light states change with no problem!
