I’m not sure is it related to HA Cloud, but sometimes when I ask Alexa to switch on/off stuffs, it will reply “Sorry, [device name] isn’t responding”. It affects every devices exposed by HA cloud. I have to restart HA to make it works again.
I have encountered the same problem (‘device isn’t responding’). Thanks for breaking it down @walt.
Restarting my Pi with hassio (e.g. restarting HA) does not seem to actually resolve this (consistently) for my HA instance, which strikes me as odd. I’ve set up hassio to get itself a fixed local IP address, and although I can reach my HA instance through the DuckDNS forward, I just noticed my hassio-pi actually does not have a DHCP listing in the modem. I wonder if it’s related to @walt’s observation that the HA cloud component tries to call a local IP.
Have the same problem, either restart HA or reconnect the account on the HA configuration panel fixes the issue. Hope this gets fix on the next release.
Wrote a little shell script that I am calling from cron every hour to log off and then back on to the cloud service. For now it’s keeping my Alexa happy.
Replace api_password with your password, [email protected] and password with your home assistant cloud credentials, and hass-server with the IP or hostname of your HASS instance.
It’s a shell script. You can run it from any system that can access your HASS server.
I’m running mine from a cronjob on my standard HASS server.
I’ve never used HASS.IO, but I don’t think that a script or a cronjob is as easy there – You might look through the documentation here, but it appears you can use the command_line switch to do the same thing. You could also write an automation to start the command_line switch every hour.
try login out/in again from alexa app and also from HA.
If the devices in alexa app show offline, after you have log out/in, scroll down and click discover device again.
We pay for this service and they aren’t even using a proper certificate. Yes I know lets encrypt are valid certificates but what are we paying for if they are using a free one that has to be updated every 90 days only for either the update script to break or someone forgets to do it and we are in the situation we are in now and I cant turn anything on in my house without going to the GUI!
