Device limit exceeded
Why is this the case? Does this have effects on HA in general?
Logger: homeassistant.components.homekit
Source: components/homekit/__init__.py:522
Integration: HomeKit (documentation, issues)
First occurred: 9:23:10 (618 occurrences)
Last logged: 9:23:10
Cannot add switch.heizungspanel_b2 as this would exceed the 150 device limit. Consider using the filter option
Cannot add switch.heizungspanel_b1 as this would exceed the 150 device limit. Consider using the filter option
Cannot add switch.sonoff_led_ring_tresen as this would exceed the 150 device limit. Consider using the filter option
Cannot add switch.zbr3_led_ring as this would exceed the 150 device limit. Consider using the filter option
Cannot add media_player.nestaudio8685 as this would exceed the 150 device limit. Consider using the filter option
Greetings
No, only the homekit integration, and it is a limit imposed by Apple. It’s in the homekit integration documentation.
You should filter the devices exposed to homekit to only include the ones you need/want to control via homekit.
Can you please suggest how to filter this?
I have now the same problem.
Thanks!
https://www.home-assistant.io/integrations/homekit/#configure-filter
