I moved from Fibaro HC2 to Home Assistant (generic linux with a pip install). And to make my life a bit easier I moved to a docker (supervised) install. I had an extensive network of about 30 devices, but I lost 1 device in the final migration steps and even after various reboots and about 2 months time I don’t get to see the device in Home-Assistant.
I see the device generating traffic in my zwave logs and I also see it in the zwcfg_**.xml file.
I’ve not dared to copy the data from the old zwcfg_**.xml from the previous HAS(pip) install over to the HAS-Docker. But should I take this step to get it to work? Or is it too risky?
What other ways have I to get it available (without having to break down this critical device?)… It’s the 6-way socket for my living room mediacenter (Greenwave PowerNode 6)
regards,
Jelle
